doc:lps:toda3 [2018-06-15 08:42] kristoffer |
doc:lps:toda3 [2018-06-15 08:51] kristoffer |
Line 87: | Line 87: | ||
example: '' | example: '' | ||
+ | ==== Setting anchor positions ==== | ||
+ | Anchor positions can be set by the python client but it only supports ids 0-7. If you want to use more anchors there is a tool that can be used. | ||
+ | The tool uses a Crazyflie as a bridge to transmit UWB messages to the anchors. When it is started it transmits positions for all anchors over and over, | ||
+ | The tool is somewhat hackish and could use some updates, for instance the Crazyflie radio address is hardcoded in the script. Be prepared to modify the script... | ||
+ | * Create a file with your anchor positions, see tools/ | ||
+ | * Start the Crazyflie | ||
+ | * Pipe the position file into the tool '' | ||
+ | * Move the Crazyflie close to all anchors to transfer the positions | ||
