doc:lps:twr-tdma [2017-07-18 15:41] arnaud [System performance] |
doc:lps:twr-tdma [2017-07-19 11:38] arnaud [Compiling Crazyflie for TWR-TDMA ranging] |
Line 16: | Line 16: | ||
In order to activate TWR-TDMA, you need to recompile the Crazyflie firmware. Add the following to ' | In order to activate TWR-TDMA, you need to recompile the Crazyflie firmware. Add the following to ' | ||
LPS_TDMA_ENABLE=1 | LPS_TDMA_ENABLE=1 | ||
CFLAGS += -DTDMA_NSLOTS_BITS=1 | CFLAGS += -DTDMA_NSLOTS_BITS=1 | ||
Line 23: | Line 23: | ||
* **LPS_TDMA_ENABLE=1** Enable the TDMA mode for TWR | * **LPS_TDMA_ENABLE=1** Enable the TDMA mode for TWR | ||
- | * **TDMA_NSLOTS_BITS=1** Configures 2 time slot (good for 2 tags). The number of time slot is 2^TDMA_NSLOTS_BITS | + | * **TDMA_NSLOTS_BITS=1** Configures 2 time slot (good for 2 tags) per frame. The number of time slot per frame is 2^TDMA_NSLOTS_BITS |
- | * **TDMA_SLOT** Optionally hardcode the time slot. See bellow for time slot auto-configuration. | + | * **TDMA_SLOT** Optionally hardcode the time slot. See bellow for time slot auto-configuration |
===== Configuring time slots ===== | ===== Configuring time slots ===== |
