User Tools
Site Tools
index
Differences
Link to this comparison view
Next revision
Previous revision
Last revision Both sides next revision
index [2017-01-16 15:13]
macke
index [2017-05-23 15:33]
jan [Expansion decks for Crazyflie 2.0]
Line 35: Line 35:
   * [[projects:​crazyflie2:​expansionboards:​proto|Prototyping deck]]: The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0.   * [[projects:​crazyflie2:​expansionboards:​proto|Prototyping deck]]: The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0.
   * [[projects:​crazyflie2:​expansionboards:​breakout|Breakout deck]]: Makes all 20 pins in the Crazyflie 2.0 expansion port available.   * [[projects:​crazyflie2:​expansionboards:​breakout|Breakout deck]]: Makes all 20 pins in the Crazyflie 2.0 expansion port available.
 +  * [[projects:​crazyflie2:​expansionboards:​microsd|micro-SD deck]]: Adds the possibility to read and write files to micro-SD card.
 +  * [[projects:​crazyflie2:​expansionboards:​zranger|Z-ranger expansion deck]]: Expansion deck for precise height control.
 +  * [[projects:​crazyflie2:​expansionboards:​bosch|Bosch Sensortec expansion deck]]: Expansion deck with a variety of Bosch Sensortec sensors
 ==== Radio USB dongels ==== ==== Radio USB dongels ====
   * [[projects:​crazyradio:​index|Crazyradio]]:​ The Crazyradio is a 2.4 GHz radio USB dongle.   * [[projects:​crazyradio:​index|Crazyradio]]:​ The Crazyradio is a 2.4 GHz radio USB dongle.
index.txt · Last modified: 2019-04-01 15:48 by tobias
