index [2016-02-01 15:30] bjorn |
index [2021-09-13 16:56] (current) kristoffer |
| - | Welcome to the Bitcraze Wiki! This wiki has been set up to host information | + | <WRAP center round important 60%> |
| - | * **[[https:// | + | This wiki has been deprecated |
| - | * **Wiki projects**: Contains project specific hardware information, | + | </WRAP> |
| - | * **Wiki documentation**: | + | ====== Welcome to the Bitcraze Wiki! ====== |
| - | * **[[http:// | + | |
| - | We are currently working on restructuring the documentation according to the list above, so it might not always be the case. We appreciate all the help we can get, so if you would like access | + | **This wiki is one of several sources of information for Bitcraze projects, here is a rough guide of where to look:** |
| - | The hardware for our projects are available for purchase at [[http://www.seeedstudio.com/depot/bitcraze-m-64.html | Seeedstudio]]. | + | * [[https://www.bitcraze.io|Web]]: Product information, |
| + | * [[https://wiki.bitcraze.io|Wiki]]: In depth documentation, | ||
| + | * [[https:// | ||
| - | One of our goals is to only use open source software when developing | + | ===== Contributions ===== |
| + | **Everything | ||
| + | * The sources for the web and other projects are on github, [[https:// | ||
| + | * On the forum you can easily create a user and you are good to go. | ||
| + | * If you want access | ||
| + | ===== Products ===== | ||
| + | ==== Quadcopters ==== | ||
| + | * [[projects: | ||
| + | ==== Expansion decks for Crazyflie 2.0 ==== | ||
| + | * [[projects:crazyflie2:expansionboards: | ||
| + | ==== Radio USB dongels ==== | ||
| + | ==== Local position system ==== | ||
| + | ==== Accessories ==== | ||
| + | ==== Software ==== | ||
| - | <WRAP group> | ||
| - | <WRAP half column> | ||
| - | ===== Projects ===== | ||
| - | The project pages contain information relevant for specific projects like assembly instructions and relevant documentation links. | ||
| - | * [[projects: | ||
| - | * [[kicad: | ||
| - | ===== Misc ===== | ||
| - | * [[misc: | ||
| - | * [[misc: | ||
| - | * [[misc: | ||
| - | * [[misc: | ||
| - | * [[misc: | ||
| - | * [[misc: | ||
| ===== Documentation ===== | ===== Documentation ===== | ||
| - | Since a lot of the documentation is shared among different projects it's been collected in a separate structure. | ||
| - | * [[doc: | ||
| - | * [[doc: | ||
| + | **Since a lot of the documentation is shared among different projects it's been collected in a separate structure.** | ||
| + | * [[doc: | ||
| + | * [[doc: | ||
| + | * [[doc: | ||
| + | ===== Misc ===== | ||
| + | * [[misc: | ||
| + | * [[misc: | ||
| + | * [[misc: | ||
| + | * [[misc: | ||
