User Tools
Site Tools
index
Differences
Link to this comparison view
Next revision
Previous revision
index [2013-01-31 20:52]
macke
index [2021-09-13 16:56] (current)
Line 1: Line 1:
-====== Bitcraze Wiki ======+<WRAP center round important 60%>
 +This wiki has been deprecated and will be archived. Please go to [[https://www.bitcraze.io/]].
 +</WRAP>
 +====== Welcome to the Bitcraze Wiki======
-This wiki has been setup to host technical information and documentations of various Bitcraze projects.+**This wiki is one of several sources of information for Bitcraze projects, here is a rough guide of where to look:**
-One of our goals is to only use open source software when developing and so far we have managed to stick to it using tools for design of electronicsmechanicssoftware and website. [[misc:osstools:index Here's a list of the tools we use]].+  * [[https://www.bitcraze.io|Web]]: Product information, tutorials and company information - all you need to get started.
 +  * [[https://wiki.bitcraze.io|Wiki]]: In depth documentationspecificationsarchitecture - the nitty gritty details.
 +  * [[https://forum.bitcraze.io|Forum]]: Discussions and help - ask questions and discuss with the community and Bitcraze.
 +  * [[https://github.com/bitcraze|Github]]: Implementation discussions, project specific documentation and issue trackers - all the sources when you want to explore, improve and contribute.
-The hardware for our projects are available for purchase at [[http://www.seeedstudio.com/depot/bitcraze-m-64.html | Seeedstudio]].+===== Contributions =====
-===== Projects ===== +----
-  * [[projects:crazyflie:index|Crazyflie]]: The Crazyflie micro quadcopter +
-  * [[projects:crazyradio:index|Crazyradio]]: The USB radio dongle used to control the CrazyFlie quadcopter. This can be used for other purpose as well.+
-===== Kicad ===== +
-  * [[kicad:library|KiCad library]]: Components/footprints/logos that we use+**Everything is open for contributions and we love your input!**
 +  * The sources for the web and other projects are on github, [[https://help.github.com/articles/using-pull-requests/|contribute through pull requests]].
 +  * On the forum you can easily create a user and you are good to go.
 +  * If you want access to help out with the Wiki drop us an email at <wiki@bitcraze.se>
 +===== Products =====
 +==== Quadcopters ====
 +  * [[projects:crazyflie:index|Crazyflie 1.0]]: The first Crazyflie Nano Quadcopter.
 +  * [[projects:crazyflie2:index|Crazyflie 2.X]]: The latest generation of the Crazyflie.
 +==== Expansion decks for Crazyflie 2.0 ====
 +  * [[projects:crazyflie2:expansionboards:ledring|LED-ring deck]]: The deck is designed to be installed on the bottom of the Crazyflie 2.0.
 +  * [[projects:crazyflie2:expansionboards:buzzer|Buzzer deck]]: Designed to be installed either on the top or the bottom of the Crazyflie 2.0.
 +  * [[projects:crazyflie2:expansionboards:bigquad|BigQuad deck]]: With the BigQuad deck you can transform your Crazyflie 2.0 to a bigger quad.
 +  * [[projects:crazyflie2:expansionboards:qi|Qi charger deck]]: The Qi wireless charging deck allows charging the Crazyflie 2.0 battery with a standard Qi wireless charger.
 +  * [[projects:crazyflie2:expansionboards:proto|Prototyping deck]]: The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0.
 +  * [[projects:crazyflie2:expansionboards:breakout|Breakout deck]]: Makes all 20 pins in the Crazyflie 2.0 expansion port available.
 +  * [[projects:crazyflie2:expansionboards:microsd|micro-SD deck]]: Adds the possibility to read and write files to micro-SD card.
 +  * [[projects:crazyflie2:expansionboards:zranger|Z-ranger expansion deck]]: Expansion deck for precise height control.
 +  * [[projects:crazyflie2:expansionboards:bosch|Bosch Sensortec expansion deck]]: Expansion deck with a variety of Bosch Sensortec sensors
 +==== Radio USB dongels ====
 +  * [[projects:crazyradio:index|Crazyradio]]: The Crazyradio is a 2.4 GHz radio USB dongle.
 +  * [[projects:crazyradiopa:index|Crazyradio PA]]: The Crazyradio PA is a 2.4 GHz radio USB dongle with a power amplifier.
 +==== Local position system ====
 +  * [[projects:lps:index|Indoor positioning]]: The local positioning system is based on the DecaWave DWM1000 module.
 +==== Accessories ====
 +  * [[projects:accessories:chg500:index|Li-Po charger (500mA)]]: External 500mA Li-Po charger
 +==== Software ====
 +  * [[projects:virtualmachine:index|Bitcraze Virtual Machine]]: Virtual machine that can be used to quickly get started with development.
 +  * [[projects:dockerbuilderimage:index|The toolbelt and Docker Builder Images]]: A utility to enable builds of software modules without installing toolchains, frameworks and other dependencies.
 +===== Documentation =====
 +**Since a lot of the documentation is shared among different projects it's been collected in a separate structure.**
 +  * [[doc:crazyflie:index|Crazyflie projects documentation]]: Generic documentation such as protocols, clients and APIs.
 +  * [[doc:crazyradio:index|Crazyradio projects documentation]]: Generic documentation.
 +  * [[doc:crazyflie:client:pycfclient:index|Crazyflie PC client documentation]]: A guide to using the Crazyflie client application.
 +===== Misc =====
 +    * [[misc:downloads:index|Downloads]]: Binary downloads for firmware/software/clients etc.
 +    * [[misc:hacks:index|Build logs/hacks]]: Documentation of hacks/mods that we and other have done.
 +    * [[misc:investigations:index|Investigations]]: Detailed documentation of various investigations.
 +    * [[misc:wiki:index|About the wiki]]: Structure and how to get access.
index.1359661920.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
