User Tools
Site Tools
index
Differences
Link to this comparison view
Next revision
Previous revision
index [2016-03-30 16:55]
bjorn
index [2021-09-13 16:56] (current)
Line 1: Line 1:
 +This wiki has been deprecated and will be archived. Please go to [[https://www.bitcraze.io/]].
 +</WRAP>
 ====== Welcome to the Bitcraze Wiki! ====== ====== Welcome to the Bitcraze Wiki! ======
Line 26: Line 29:
 ==== Quadcopters ==== ==== Quadcopters ====
   * [[projects:crazyflie:index|Crazyflie 1.0]]: The first Crazyflie Nano Quadcopter.   * [[projects:crazyflie:index|Crazyflie 1.0]]: The first Crazyflie Nano Quadcopter.
-  * [[projects:crazyflie2:index|Crazyflie 2.0]]: The latest generation of the Crazyflie.+  * [[projects:crazyflie2:index|Crazyflie 2.X]]: The latest generation of the Crazyflie.
 ==== Expansion decks for Crazyflie 2.0 ==== ==== Expansion decks for Crazyflie 2.0 ====
Line 35: Line 38:
   * [[projects:crazyflie2:expansionboards:proto|Prototyping deck]]: The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0.   * [[projects:crazyflie2:expansionboards:proto|Prototyping deck]]: The prototyping deck allows electronic circuits to be attached on Crazyflie 2.0.
   * [[projects:crazyflie2:expansionboards:breakout|Breakout deck]]: Makes all 20 pins in the Crazyflie 2.0 expansion port available.   * [[projects:crazyflie2:expansionboards:breakout|Breakout deck]]: Makes all 20 pins in the Crazyflie 2.0 expansion port available.
 +  * [[projects:crazyflie2:expansionboards:microsd|micro-SD deck]]: Adds the possibility to read and write files to micro-SD card.
 +  * [[projects:crazyflie2:expansionboards:zranger|Z-ranger expansion deck]]: Expansion deck for precise height control.
 +  * [[projects:crazyflie2:expansionboards:bosch|Bosch Sensortec expansion deck]]: Expansion deck with a variety of Bosch Sensortec sensors
 ==== Radio USB dongels ==== ==== Radio USB dongels ====
   * [[projects:crazyradio:index|Crazyradio]]: The Crazyradio is a 2.4 GHz radio USB dongle.   * [[projects:crazyradio:index|Crazyradio]]: The Crazyradio is a 2.4 GHz radio USB dongle.
Line 42: Line 47:
 ==== Local position system ==== ==== Local position system ====
   * [[projects:lps:index|Indoor positioning]]: The local positioning system is based on the DecaWave DWM1000 module.   * [[projects:lps:index|Indoor positioning]]: The local positioning system is based on the DecaWave DWM1000 module.
 +==== Accessories ====
 +  * [[projects:accessories:chg500:index|Li-Po charger (500mA)]]: External 500mA Li-Po charger
 ==== Software ==== ==== Software ====
index.1459349738.txt.gz · Last modified: 2016-03-30 16:55 by bjorn
