User Tools
Site Tools
misc:hacks:betaflight
Differences
Link to this comparison view
Next revision
Previous revision
misc:hacks:betaflight [2017-04-12 23:33]
theseankelly [Configuring Transmitter]
misc:hacks:betaflight [2021-06-24 16:43]
Line 1: Line 1:
 +</WRAP>
 ====== Betaflight for Crazyflie 2.0 ====== ====== Betaflight for Crazyflie 2.0 ======
Line 19: Line 24:
 ===== Building ===== ===== Building =====
-<WRAP center round info>
-TEMPORARY: As of this writing, the changes for the Crazyflie 2.0 target have not been merged back into the Betaflight repo -- temporarily working out of a [[https://github.com/theseankelly/betaflight/commits/cf2|private fork]]. Intent is to merge into Betaflight ASAP once a few bugs in the latest Betaflight are ironed out.
-</WRAP>
 Execute the following from a bash shell (uses the same toolchain as the crazyflie-firmware project -- this can be done on the [[projects:virtualmachine:index|Bitcraze]] VM for example) Execute the following from a bash shell (uses the same toolchain as the crazyflie-firmware project -- this can be done on the [[projects:virtualmachine:index|Bitcraze]] VM for example)
-  - git clone https://github.com/theseankelly/betaflight +  - git clone https://github.com/betaflight/betaflight
-  - git checkout cf2+
   - export TARGET=CRAZYFLIE2   - export TARGET=CRAZYFLIE2
   - make   - make
-You should see "betaflight_3.2.0_CRAZYFLIE2.hex" appear in the obj directory of the project.+You should see "betaflight_3.2.0_CRAZYFLIE2.hex" (version number may be newer) appear in the obj directory of the project.
 ===== Flashing ===== ===== Flashing =====
Line 43: Line 44:
 ===== Configuring Betaflight ===== ===== Configuring Betaflight =====
-The defaults after flashing should be sufficient for flight.+The defaults after flashing should be sufficient for flight.
 +Some things of note:
 +  * It's suggested to change the brushed motor PWM to something higher to reduce audible noise - 24khz works well.
 +  * Configured to use a TARGET_CUSTOM serial Rx protocol - this is a new feature in betaflight for the crazyflie so that the NRF51 firmware does not need to change. This option was very recently added to the betaflight/cleanflight configurators, so make sure you're using the latest version of the configurators (or just don't change the serialRx protocol drop down -- it will be a blank white box on earlier configurators
 +  * PIDs have not been tuned for the crazyflie -- the stock PIDs seem to be doing quite well though.
 ===== Configuring Transmitter ===== ===== Configuring Transmitter =====
misc/hacks/betaflight.txt · Last modified: 2021-06-24 16:43 by kimberly
