Next revision Both sides next revision | |||
misc:hacks:dual_motors [2013-07-09 09:01] macke created |
misc:hacks:dual_motors [2013-07-09 09:14] macke |
Line 11: | Line 11: | ||
====== Building ====== | ====== Building ====== | ||
- | - Remove the protective edge bottom of the motor mount that stops the motor from sliding out at the bottom | + | 1) Remove the protective edge bottom of the motor mount that stops the motor from sliding out at the bottom |
- | - Twist the wires for the two motors and insert them into the mount. You can either do like the image with each motor twisted or twisting black and white together from the two motors | + | |
- | - Mount the motors in the holes. Follow [[projects: | + | |
- | - Now mount the propellers. Follow [[projects: | + | |
- | - Attach some landing gear or find something like a CD-spool to launch from | + | |
- | - Done! | + | |
+ | 2) Twist the wires for the two motors and insert them into the mount. You can either do like the image with each motor twisted or twisting black and white together from the two motors | ||
+ | 3) Mount the motors in the holes. Follow [[projects: | ||
+ | 4) Now mount the propellers. Follow [[projects: | ||
+ | 5) Attach some landing gear or find something like a CD-spool to launch from | ||
+ | 6) Done! | ||
