misc:hacks:et6i [2013-05-31 21:44] foosel created |
misc:hacks:et6i [2021-06-24 16:44] kimberly |
======= Using an ESKY ET6I Remote Control for flying ======= | ======= Using an ESKY ET6I Remote Control for flying ======= | ||
The ESKY ET6I Remote Control is compatible to the Crazyflie as they share the same radio chipset. In order to use the RC **instead of** the Crazyflie PC Client, you'll have to compile the firmware with '' | The ESKY ET6I Remote Control is compatible to the Crazyflie as they share the same radio chipset. In order to use the RC **instead of** the Crazyflie PC Client, you'll have to compile the firmware with '' | ||
Line 9: | Line 12: | ||
- | This will create a new firmware file '' | + | This will create a new firmware file '' |
+ | If you do not want to build the firmware on your own, you can use the newest precompiled binary from here: | ||
+ | [[https:// | ||
You'll have to make some adjustments on your RC in order for this to work. First, take a look into the battery compartment of your RC. There you'll see two switches. Make sure switch 1 is set to '' | You'll have to make some adjustments on your RC in order for this to work. First, take a look into the battery compartment of your RC. There you'll see two switches. Make sure switch 1 is set to '' | ||
Then close the battery compartment again and take a look at the lower right front of your RC. There are four switches, one each for AILeron, ELEvator, THRottle and RUDder. You'll have to adjust these, depending on your RC's Mode. If you have a Mode 1 RC (throttle and rudder on the right stick) the correct setting is AIL-up, ELE-down, THR-up, RUD-down. If on the other hand you have a Mode 2 RC (throttle + rudder on the left stick) you'll need to set those switches to AIL-down, ELE-up, THR-down, RUD-up. | Then close the battery compartment again and take a look at the lower right front of your RC. There are four switches, one each for AILeron, ELEvator, THRottle and RUDder. You'll have to adjust these, depending on your RC's Mode. If you have a Mode 1 RC (throttle and rudder on the right stick) the correct setting is AIL-up, ELE-down, THR-up, RUD-down. If on the other hand you have a Mode 2 RC (throttle + rudder on the left stick) you'll need to set those switches to AIL-down, ELE-up, THR-down, RUD-up. | ||
With this done and your Crazyflie reflashed with the ESKY-enabled firmware, startup your Crazyflie, then after the steady heartbeat from the red led indicates that it's done, make sure your throttle stick is all the way down and then switch on your RC. Crazyflie and RC should now bind and your Crazyflie should react to your RC's input. | With this done and your Crazyflie reflashed with the ESKY-enabled firmware, startup your Crazyflie, then after the steady heartbeat from the red led indicates that it's done, make sure your throttle stick is all the way down and then switch on your RC. Crazyflie and RC should now bind and your Crazyflie should react to your RC's input. | ||
Line 23: | Line 29: | ||
:!: **Careful** :!: When your Crazyflie is flashed in ESKY mode, be careful to not switch on the RC when your Crazyflie is connected to the USB cable for charging. It will bind to the RC and it will react to any (accidental) RC commands you give it, including trying to fly away with the USB cable still attached. | :!: **Careful** :!: When your Crazyflie is flashed in ESKY mode, be careful to not switch on the RC when your Crazyflie is connected to the USB cable for charging. It will bind to the RC and it will react to any (accidental) RC commands you give it, including trying to fly away with the USB cable still attached. | ||
- | If you want a bit more pep to your RC controlled Crazyflie((the regular ESKY mode is a bit slow-ish)) you might want to take a look at the [[https://bitbucket.org/jodell/crazyflie-firmware/commits/02d0d91811a5a9fe92f68dd008bfebe60764b7de|adjustments '' | + | ====== Features of the eSky-Firmware ====== |
+ | Since the first version of the eSky binary | ||
+ | With the new version | ||
+ | This sensitivity will be interpolated from the min. and max. values, based on the CH5's knob position. | ||
+ | {{:projects: | ||
+ | #define M_YAW_MIN | ||
+ | #define M_PITCH_MIN | ||
+ | #define M_ROLL_MIN | ||
+ | #define M_THRUST_MIN | ||
+ | #define M_YAW_MAX | ||
+ | #define M_PITCH_MAX | ||
+ | #define M_ROLL_MAX | ||
+ | #define M_THRUST_MAX | ||
+ | **Important: | ||
