misc:hacks:gps [2015-03-01 23:33] fred |
misc:hacks:gps [2015-07-15 16:31] 127.0.0.1 external edit |
+ | ====== Adding a u-blox MAX-7 GPS module ====== | ||
+ | ===== What you need ===== | ||
+ | * u-blox MAX-7 GPS breakout (we have [[http:// | ||
+ | * KDE Marble built with Python bindings | ||
+ | ===== How to get it working ===== | ||
+ | These instructions are valid for Ubuntu 13.10 but similar steps should work with other distros. | ||
+ | * Attach the u-blox beakout to the expansion header by connecting the following pins (breakout -> Crazyflie expansion header): | ||
+ | * GND -> DGND (pin 17) | ||
+ | * VCC -> VCC (pin 15) | ||
+ | * TXD -> TX (pin 5) | ||
+ | * RXD -> RX (pin 3) | ||
+ | * Since the Python bindings for Marble isn't built by default you will have to build Marble from source and enable these (instructions taken from [[http:// | ||
+ | sudo apt-get install python-sip-dev python-qt4-dev kdelibs5-dev python-kde4 | ||
+ | git clone git:// | ||
+ | mkdir -p ~/ | ||
+ | cd ~/ | ||
+ | cmake ~/ | ||
+ | make | ||
+ | sudo make install | ||
+ | * Make sure you have the correct firmware/ | ||
+ | ===== Tweaking and development ===== | ||
+ | There' | ||
+ | Getting a position fix will not be as easy as with your phone, so make sure to be outside (or at least stick the Crazyflie a couple of meters outside the window). | ||
+ | If you don't have a GPS module you can still use the [[projects: |
