misc:hacks:gps [2014-01-08 15:29] macke |
misc:hacks:gps [2015-07-15 16:31] 127.0.0.1 external edit |
Line 2: | Line 2: | ||
- | ====== What you need ====== | + | ===== What you need ===== |
* u-blox MAX-7 GPS breakout (we have [[http:// | * u-blox MAX-7 GPS breakout (we have [[http:// | ||
* KDE Marble built with Python bindings | * KDE Marble built with Python bindings | ||
- | ====== How to get it working | + | ===== How to get it working ===== |
These instructions are valid for Ubuntu 13.10 but similar steps should work with other distros. | These instructions are valid for Ubuntu 13.10 but similar steps should work with other distros. | ||
Line 16: | Line 16: | ||
* Since the Python bindings for Marble isn't built by default you will have to build Marble from source and enable these (instructions taken from [[http:// | * Since the Python bindings for Marble isn't built by default you will have to build Marble from source and enable these (instructions taken from [[http:// | ||
- | sudo apt-get install python-sip-dev python-qt4-dev | + | sudo apt-get install python-sip-dev python-qt4-dev |
git clone git:// | git clone git:// | ||
Line 25: | Line 25: | ||
sudo make install | sudo make install | ||
- | * Make sure you have the correct firmware/ | + | * Make sure you have the correct firmware/ |
- | ====== Tweaking and development | + | ===== Tweaking and development ===== |
- | There' | + | There' |
Getting a position fix will not be as easy as with your phone, so make sure to be outside (or at least stick the Crazyflie a couple of meters outside the window). | Getting a position fix will not be as easy as with your phone, so make sure to be outside (or at least stick the Crazyflie a couple of meters outside the window). | ||
If you don't have a GPS module you can still use the [[projects: | If you don't have a GPS module you can still use the [[projects: |
