misc:hacks:kinect [2013-08-19 19:37] macke |
misc:hacks:kinect [2021-06-24 16:45] (current) kimberly |
| ====== Piloting the Crazyflie with the Kinect ====== | ====== Piloting the Crazyflie with the Kinect ====== | ||
| - | This is documentation for the proof-of-concept where the Kinect is used to automatically pilot the Crazyflie. The code is available in the [[https://bitbucket.org/ | + | This is documentation for the proof-of-concept where the Kinect is used to automatically pilot the Crazyflie. The code is available in the [[https://github.com/ |
| The application is intended as a proof-of-concept to show that this is possible and also to act as a starting point for anyone that wants to do some development using the Kinect and the Crazyflie. The application will probably not work out of the box for everyone since the image processing is still pretty basic and some tuning might be needed to detect the Crazyflie. | The application is intended as a proof-of-concept to show that this is possible and also to act as a starting point for anyone that wants to do some development using the Kinect and the Crazyflie. The application will probably not work out of the box for everyone since the image processing is still pretty basic and some tuning might be needed to detect the Crazyflie. | ||
| Line 26: | Line 29: | ||
| python setup.py install | python setup.py install | ||
| - | * Clone the crazyflie-pc-client | + | * Clone the crazyflie-clients-python |
| - | hg clone https://bitbucket.org/ | + | git clone https://github.com/ |
| - | hg update | + | git checkout |
| * Connect your Kinect and set up the test as explained below | * Connect your Kinect and set up the test as explained below | ||
| * Start the cfkinect client | * Start the cfkinect client | ||
| - | cd crazyflie-pc-client/bin | + | cd crazyflie-clients-python/bin |
| ./cfkinect | ./cfkinect | ||
| - | * The Crazyflie should now fly itself but it will probably require some tweaking... Note that as soon as the application | + | * The Crazyflie should now fly itself but it will probably require some tweaking... Note that as soon as the application |
| The set-point can be moved when holding down the mouse button in the RGB window. | The set-point can be moved when holding down the mouse button in the RGB window. | ||
| Line 44: | Line 47: | ||
| To tweak and develop have a look at the following files: | To tweak and develop have a look at the following files: | ||
| - | crazyflie-pc-client/ | + | crazyflie-clients-python/ |
| Line 63: | Line 66: | ||
| ====== Conclusions ====== | ====== Conclusions ====== | ||
| ===== Depth ===== | ===== Depth ===== | ||
| - | The most tricky part to detect is the depth which is why we used the Kinect. The problem is that the effective range of the IR laser detection is about 0.1 - 2 meters, which is a bit too small. At two meters the RGB image is about 1.5x1.5 meters which is a bit too small to do flight maneuvers. To do more fancy stuff a larger area would be required which means that the depth measurement would be lost with the Kinect. | + | The most tricky part to detect is the depth which is why we used the Kinect. The problem is that, with the current implementation, |
| ===== Yaw ===== | ===== Yaw ===== | ||
| - | Only using one visual marker makes it impossible to detect the yaw. So more visual markers would have to be added and tracked to fix this. | + | Only using one visual marker makes it impossible to detect the yaw. So more visual markers would have to be added and tracked to fix this. One idea investigated is to add a black dot in the center of the red ball and to try to keep this dot in the middle as seen from the camera. |
| ===== FPS ===== | ===== FPS ===== | ||
| Line 78: | Line 81: | ||
| The regulation has to be improved. | The regulation has to be improved. | ||
| + | Better result could be achieved by calibrating the kinect(?). | ||
