misc:hacks:landing_gear [2013-05-13 16:23] skube [Nerf dart cushions] |
misc:hacks:landing_gear [2015-07-15 16:31] 127.0.0.1 external edit |
====== Landing gear ====== | ====== Landing gear ====== | ||
- | The Crazyflie can be landed on its motor mounts perfectly fine. However the motors have a built-in safety mechanism to slide down in them if a force is applied from above (e.g. if you hit the ceiling), which can lead to the motors sticking out below the mounts. This in turn -- if unnoticed -- leads to you not landing on the mounts but instead on the underside of the motors which means the motor wires, which most probably reduce the lifetime of these wires. | + | The Crazyflie can be landed on its motor mounts perfectly fine. However the motors have a built-in safety mechanism to slide down in them if a force is applied from above (e.g. if you hit the ceiling |
===== Nerf dart cushions ===== | ===== Nerf dart cushions ===== | ||
Line 11: | Line 11: | ||
NERF darts happen to have the perfect inner diameter to also work great with a simple pressure fit on the motor mounts. Just cut off 4 parts of ~1cm length and cut a small notch of ~3x3mm in their tops (this is for the making room for the arms). The NERF dart part can then be slid onto the motor mount with the arm of the motor resting in the notch. Holds well without any glue in most crash situations and weighs next to nothing. | NERF darts happen to have the perfect inner diameter to also work great with a simple pressure fit on the motor mounts. Just cut off 4 parts of ~1cm length and cut a small notch of ~3x3mm in their tops (this is for the making room for the arms). The NERF dart part can then be slid onto the motor mount with the arm of the motor resting in the notch. Holds well without any glue in most crash situations and weighs next to nothing. | ||
+ | If you got more than one color of them, you can even make your NERF based landing gear help with orientation too, just use one color for Motor 1 and another for all the other motors (example [[https:// | ||
===== Earplugs cut in half ===== | ===== Earplugs cut in half ===== | ||
