misc:hacks:leapmotion [2013-08-12 18:21] macke |
misc:hacks:leapmotion [2015-07-15 16:31] 127.0.0.1 external edit |
====== Flying the Crazyflie with the Leapmotion ====== | ====== Flying the Crazyflie with the Leapmotion ====== | ||
- | There' | + | There' |
**Please note:** This is VERY experimental so be careful! | **Please note:** This is VERY experimental so be careful! | ||
Line 10: | Line 10: | ||
* Download the SDK and unpack it | * Download the SDK and unpack it | ||
* Download and install the normal installer (for Linux the installer is in the SDK) | * Download and install the normal installer (for Linux the installer is in the SDK) | ||
- | * Copy the file '' | + | * Copy the file '' |
- | * Copy the files in the '' | + | * Copy the files in the '' |
* Plug your Leap Motion | * Plug your Leap Motion | ||
* Start up the Leap Motion daemon if it's not already started. On Linux this is done by issuing the following command | * Start up the Leap Motion daemon if it's not already started. On Linux this is done by issuing the following command | ||
Line 17: | Line 17: | ||
sudo leapd | sudo leapd | ||
- | * Clone the crazyflie-pc-client | + | * Clone the crazyflie-clients-python |
- | hg clone https://bitbucket.org/ | + | git clone https://github.com/ |
- | hg update | + | git checkout |
* Start the normal client | * Start the normal client | ||
- | cd crazyflie-pc-client/bin | + | cd crazyflie-clients-python/bin |
./cfclient | ./cfclient | ||
Line 34: | Line 34: | ||
====== Tweaking ====== | ====== Tweaking ====== | ||
- | Have a look in the '' | + | Have a look in the '' |
