misc:hacks:leapmotion [2013-08-12 18:21] macke |
misc:hacks:leapmotion [2021-06-24 16:45] (current) kimberly |
| ====== Flying the Crazyflie with the Leapmotion ====== | ====== Flying the Crazyflie with the Leapmotion ====== | ||
| - | There' | + | There' |
| **Please note:** This is VERY experimental so be careful! | **Please note:** This is VERY experimental so be careful! | ||
| Line 10: | Line 13: | ||
| * Download the SDK and unpack it | * Download the SDK and unpack it | ||
| * Download and install the normal installer (for Linux the installer is in the SDK) | * Download and install the normal installer (for Linux the installer is in the SDK) | ||
| - | * Copy the file '' | + | * Copy the file '' |
| - | * Copy the files in the '' | + | * Copy the files in the '' |
| * Plug your Leap Motion | * Plug your Leap Motion | ||
| * Start up the Leap Motion daemon if it's not already started. On Linux this is done by issuing the following command | * Start up the Leap Motion daemon if it's not already started. On Linux this is done by issuing the following command | ||
| Line 17: | Line 20: | ||
| sudo leapd | sudo leapd | ||
| - | * Clone the crazyflie-pc-client | + | * Clone the crazyflie-clients-python |
| - | hg clone https://bitbucket.org/ | + | git clone https://github.com/ |
| - | hg update | + | git checkout |
| * Start the normal client | * Start the normal client | ||
| - | cd crazyflie-pc-client/bin | + | cd crazyflie-clients-python/bin |
| ./cfclient | ./cfclient | ||
| Line 34: | Line 37: | ||
| ====== Tweaking ====== | ====== Tweaking ====== | ||
| - | Have a look in the '' | + | Have a look in the '' |
