User Tools
Site Tools
misc:hacks:rasberrypi
Differences
Link to this comparison view
Next revision
Previous revision
misc:hacks:rasberrypi [2013-05-21 13:48]
foosel [Make the client startup automatically on Crazyradio plug in]
misc:hacks:rasberrypi [2013-10-03 23:51]
absoloodle37 Added links to the SD-card image page and Crubyflie
Line 1: Line 1:
 ====== Using the Raspberry Pi as a base station for flying ====== ====== Using the Raspberry Pi as a base station for flying ======
-You should setup the CF Headless client (see [[#current_state_of_the_headless_client|below]]) instead of the regular PC client on your Pi, since the UI seems to a bit too heavyweight for the Pi (controlling got **very** laggy during tests).+In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box.
 +The full SD-card image, and instructions on how to install it are located [[http://wiki.bitcraze.se/projects:crazyflie:binaries:raspberrypi|here.]]
 +Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user.  This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/Debian/Raspbian.  It allows you to adjust control variables (like X-mode or max thrust) by changing the values in a configuration file.  For more information visit [[https://github.com/hsanjuan/crubyflie|the Crubyflie installation page.]]
 +====== Manual Installation =====
 +As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi.  You should setup the CF Headless client (see [[#current_state_of_the_headless_client|below]]) instead of the regular PC client on your Pi, since the UI seems to a bit too heavyweight for the Pi (controlling got **very** laggy during tests).
 For the following installation instructions it is assumed that you are running the popular [[http://www.raspbian.org|Raspbian]] distrubution on your Pi.  For the following installation instructions it is assumed that you are running the popular [[http://www.raspbian.org|Raspbian]] distrubution on your Pi.
Line 29: Line 37:
 Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that ''python2'' could not be found, edit ''~/crazyflie-pc-client/bin/cfheadless'' and change the ''python2'' in the first line to ''python'')): Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that ''python2'' could not be found, edit ''~/crazyflie-pc-client/bin/cfheadless'' and change the ''python2'' in the first line to ''python'')):
-  python ~/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config>+  python ~/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config (without the .json suffix)>
 The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands:
Line 81: Line 89:
 INFO:cflib.crazyflie:Param TOC finished updating INFO:cflib.crazyflie:Param TOC finished updating
 INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/10/250K] INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/10/250K]
 +</code>
 +===== Manually Customizing Your .json Configuration File =====
 +If you created a customized .json file for your xbox controller using a Windows PC and the cfclient GUI and are planning to copy it over to your Raspberry Pi, here is some advice:
 +-save the new .json file as something different than the default, so you can recognize it easily.  e.g. xbox360new.json
 +-the new .json file is not located in the Program Files(x64)/cfclient/input folder along with all the other default .json files; it's actually located in a hidden folder in your home directory.  Use the run... command from the start menu to get to it.  Type C:\Users\<your user name>\AppData\Roaming\cfclient\input\ to get to the right location of your new .json file
 +-copy your new .json file into the correct RPi folder: /crazyflie-pc-client/conf/input/ Getting your customized .json file from your windows pc to your raspberry pi can be tricky.  Emailing it to yourself and accessing it using a RPi internet browser (like Midori) won't work because most email sites (hotmail, Gmail, etc.) require Java to access and RPi can't use Java.  USB flash drives need to be formatted correctly and that's a pain.  Try using WinSCP to move files from your Windows PC to the RPi: (http://winscp.net/eng/index.php) I also found a solution if you have access to a Mac-- install Netatalk on your Mac (http://gettingstartedwithraspberrypi.tumblr.com/post/24398167109/file-sharing-with-afp-and-auto-discovery-with-bonjour) and your RPi will show up magically in the finder window on your Mac.
 +<code>sudo apt-get install netatalk</code>
 +Verify netatalk was installed successfully on your RPi by checking the Finder window on your Mac for a "Raspberry Pi" shared drive. On your windows machine, copy your new .json file to a flash drive and plug it into your Mac. Then you can just drag/drop your new .json file from the flash drive into the /crazyflie-pc-client/conf/input/ folder using your Mac (thanks to Netatalk).
 +-the cfheadless client on RPi may not recognize the same controller channel "id" numbers that were correct for your .json file when it worked on your Windows machine.  Mine didn't recognize the roll command, so when I flew, the CF just had pitch, yaw, and thrust using the controller sticks--no roll, but the right trigger would roll the CF hard to the right.  Using nano <my xbox config file>.json, I viewed/edited my .json file to identify which "id" was associated with the Right trigger and swapped it with the roll "id" number:  Had to change the roll "id" from 4 to 0 and whatever input was associated with 4, I changed the "id" of that one to 0.  Bottom line: If your .json file isn't controlling your CF correctly, experiment with the "id" numbers in your .json file.  Just remember not to duplicate any "id" numbers.  A number can only be used once in the file.  Here's what worked for me:
 +Xbox Controller Input = id#
 +Left stick vertical = 1
 +Left stick horizontal = 0
 +Right stick vertical = 3
 +Right stick horizontal = 2
 +Right trigger = 4
 +Customize your flying configuration anyway you like using the inputs/id's above as a reference.
 +**Note**: If you have more than one controller attached, you can select the one to use using the commandline parameter ''-c''. See ''cfheadless -h'' for available command line options:
 +<code>
 +usage: cfheadless [-h] [-u URI] [-i INPUT] [-d] [-c CONTROLLER]
 +                  [--controllers]
 +optional arguments:
 +  -h, --help            show this help message and exit
 +  -u URI, --uri URI     URI to use for connection to the Crazyradio dongle,
 +                        defaults to radio://0/10/250K
 +  -i INPUT, --input INPUT
 +                        Input mapping to use for the controller, defaults to
 +                        PS3_Mode_1
 +  -d, --debug           Enable debug output
 +  -c CONTROLLER, --controller CONTROLLER
 +                        Use controller with specified id, id defaults to 0
 +  --controllers         Only display available controllers and exit
 </code> </code>
Line 94: Line 150:
 [[http://forum.bitcraze.se/viewtopic.php?p=417#p417|Marcus added]] the following things to note when using the headless client since it is a very early version: [[http://forum.bitcraze.se/viewtopic.php?p=417#p417|Marcus added]] the following things to note when using the headless client since it is a very early version:
-  * Still dependent on QT (the plan is to remove this very soon) +  * <del>Still dependent on QT (the plan is to remove this very soon)</del> Not dependent on QT anymore
-  * Not much error handling yet (the plan is to improve this) +  * <del>Not much error handling yet (the plan is to improve this)</del> Better error handling. If something does wrong the client exists.
-  * Values are still hardcoded in the script (like mapping and URI for Crazyflie). They can be changed at the bottom in lib/cfheadless.py -> **Update** [[https://bitbucket.org/bitcraze/crazyflie-pc-client/pull-request/7/command-line-options-for-radio-uri/diff|A pull request]] adding some command line options for setting the input mapping and radio URI to use has been accepted, update your client to use that. +  * <del>Values are still hardcoded in the script (like mapping and URI for Crazyflie). They can be changed at the bottom in lib/cfheadless.py</del> -> **Update** [[https://bitbucket.org/bitcraze/crazyflie-pc-client/pull-request/7/command-line-options-for-radio-uri/diff|A pull request]] adding some command line options for setting the input mapping and radio URI to use has been accepted, update your client to use that.
-  * The headless client will open the first input-device found (so don't plug more than one) +  * <del>The headless client will open the first input-device found (so don't plug more than one)</del> -> **Update** [[https://bitbucket.org/bitcraze/crazyflie-pc-client/pull-request/7/command-line-options-for-radio-uri/diff|A pull request]] adding some command line option for selecting the used input device has been accepted, update your client to use that.
-  * No good way to quit it yet so you will have to kill the process+  * <del>No good way to quit it yet so you will have to kill the process</del> Press Ctrl-C or pull the dongle
 ===== Make the client startup automatically on Crazyradio plug in ===== ===== Make the client startup automatically on Crazyradio plug in =====
Line 109: Line 165:
 </code> </code>
-and (as root) create a file ''/root/bin/cfheadless'' with the following contents:+and (as root) you will create a file ''/root/bin/cfheadless'' using the instructions below, with the following contents:
 <code bash> <code bash>
Line 115: Line 171:
 if test "$ACTION" = "add" if test "$ACTION" = "add"
 then then
-        /usr/bin/sudo -u pi /home/pi/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config> > /tmp/cfheadless.log 2>&1 &+        /usr/bin/sudo -u pi /home/pi/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config without the .json extension> > /tmp/cfheadless.log 2>&1 &
         echo $! > /tmp/cfheadless.pid         echo $! > /tmp/cfheadless.pid
 else else
Line 127: Line 183:
 </code> </code>
-Don't forget to make it executable: ''chmod +x /root/bin/cfheadless''This should now take care to startup the headless client when you plug in the dongle and (hopefully ;-)) kill it again when you unplugIf you need any additional setup to get your controller working, you can add a similar udev-rule for that to take care of everything upon plugging in the controller as well. An example for the Microsoft Wireless XBox360 controller for PC can be found [[http://forum.bitcraze.se/viewtopic.php?p=490#p490|in this forums post]] or as detailed below.+You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name.  Switch to root: ''sudo -i'' and then navigate to the /root/bin/ folder: ''cd /bin/'' Create the cfheadless file by typing: <code bash>touch cfheadless</code> to create the file.  Then <code bash>nano cfheadless</code> to edit the file, adding the code shown above ('sudo' prefix not needed because you're already root) Remember to substitute your desired config file in the appropriate place in the code above (replace<your input config...>).  Use the same method for the xbox360 file described in the section below if using a xbox360 controller:
-And for the XBox360 Controller (after an "apt-get install xboxdrv"):+For the XBox360 Controller (after an "apt-get install xboxdrv"):
 Create a udev file ''/etc/udev/rules.d/99-xbox360.rules'' with contents (if using a Microsoft wireless gaming receiver): Create a udev file ''/etc/udev/rules.d/99-xbox360.rules'' with contents (if using a Microsoft wireless gaming receiver):
Line 142: Line 198:
         killall -9 xboxdrv         killall -9 xboxdrv
 fi</code> fi</code>
 +Don't forget to make your files executable after you've created them: ''chmod +x /bin/cfheadless'' and ''chmod +x /bin/xbox360''. Once you've created the cfheadless file (and xbox360 file, if needed), exit the root mode by typing Ctl + D.  You may have to restart your RPi in order for all new udev rules to take effect. Rather than unplug/replug your RPi, consider the following command:
 +<code bash>sudo shutdown -h now -r
 +</code>
 +The -h halts all processes, the -r is the command to reboot after shutdown.
 +This should now take care to startup the headless client when you plug in the dongle and (hopefully ;-)) kill it again when you unplug. If you need any additional setup to get your controller working, you can add a similar udev-rule for that to take care of everything upon plugging in the controller as well.
 :!: **Important** :!: Due to the current state of the client, you **must** make sure to first connect your controller and power up the Crazyflie before connecting the Crazyradio dongle and thus starting the client. If the client can't find either controller or Crazyflie, it will just hang and you'll have to re-plug the dongle again. :!: **Important** :!: Due to the current state of the client, you **must** make sure to first connect your controller and power up the Crazyflie before connecting the Crazyradio dongle and thus starting the client. If the client can't find either controller or Crazyflie, it will just hang and you'll have to re-plug the dongle again.
-**Troubleshooting** If it still doesn't appear to work, try looking at the logs in the each of the following areas: +**Troubleshooting**
-  * /tmp/cfheadless.log+If it still doesn't appear to work, try looking at the logs in the each of the following areas:
 +  * /tmp/cfheadless.log (If this log indicates that there's no reference to Python2, edit crazyflie-pc-client/bin/cfheadless in order to change the 'python2' to 'python' in the beginning lines of the code.)
   * /var/log/syslog   * /var/log/syslog
 +Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group you created that has root privileges, like 'plugdev' This can be done by adding: GROUP="plugdev", to the 99-xbox360.rules udev rule (similar to the code in the crazyradio udev rule):
 +<code bash>SUBSYSTEM=="usb", ATTRS{idVendor}=="045e", ATTRS{idProduct}=="0719", GROUP="plugdev", RUN+="/root/bin/xbox360"</code>
 +Also, if running the xboxdrv command from a terminal window gives you the following error:
 +<code bash>Error couldn't claim the USB interface: LIBUSB_ERROR_BUSY</code>
 +...your controller may very well have already started automatically per the udev rule you created above and could be working correctly and currently is in use.  Make sure your wireless xbox controller is powered on and connected (green arc showing), turn on your crazyflie and then plug in your crazyradio.  Once the green light on your crazyflie flashes on, you have a connection and are ready to fly!
 ===== Make your base station portable ===== ===== Make your base station portable =====
misc/hacks/rasberrypi.txt · Last modified: 2021-06-24 16:45 by kimberly
