User Tools
Site Tools
misc:hacks:rasberrypi
Differences
Link to this comparison view
Next revision
Previous revision
misc:hacks:rasberrypi [2013-05-21 13:48]
foosel [Make the client startup automatically on Crazyradio plug in]
misc:hacks:rasberrypi [2015-02-20 15:31]
macke Page moved from projects:crazyflie:hacks:rasberrypi to misc:hacks:rasberrypi
Line 1: Line 1:
-====== Using the Raspberry Pi as a base station for flying ======
-You should setup the CF Headless client (see [[#current_state_of_the_headless_client|below]]) instead of the regular PC client on your Pi, since the UI seems to a bit too heavyweight for the Pi (controlling got **very** laggy during tests).
-For the following installation instructions it is assumed that you are running the popular [[http://www.raspbian.org|Raspbian]] distrubution on your Pi.
-===== Setup the Crazyradio dongle =====
-In order for the client to be able to access the dongle, you'll have to setup [[projects:crazyflie:pc_utils:install#fix_udev_premissions_on_linux|these udev rules]].
-===== Install the headless client =====
-Execute the following commands as your user of choice (for example the default user ''pi''):
-  cd
-  sudo apt-get install mercurial python2.7 python-usb python-pygame python-qt4
-  hg clone https://bitbucket.org/bitcraze/crazyflie-pc-client
-  cd crazyflie-pc-client
-  hg up dev-headless
-This installs the necessary dependencies for running the client, checks out the current development version from BitBucket and then switches to the branch containing the headless client.
-If you are using an XBox Controller w/ Wireless Gaming Receiver, you might need to also install the userspace driver:
-  sudo apt-get install xboxdrv
-and start it: ''sudo xboxdrv''
-Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that ''python2'' could not be found, edit ''~/crazyflie-pc-client/bin/cfheadless'' and change the ''python2'' in the first line to ''python'')):
-  python ~/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config>
-The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands:
-<code>
-pi@raspberrypi ~ $ ~/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config>
-Info: Using config path:  /home/pi/crazyflie-pc-client/lib/../conf
-Info: sys.path= ['/home/pi/crazyflie-pc-client/lib', '/home/pi/crazyflie-pc-client/lib/../conf', '/home/pi/crazyflie-pc-client/bin', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7']
-Disabling standard output for libraries!
-INFO:cfclient.utils.config:Dist config read from /home/pi/crazyflie-pc-client/lib/cfclient/configs/config.json
-INFO:cfclient.utils.input:Parsing [PS3_Mode_1.json]
-INFO:cfclient.utils.input:Parsing [xbox360_mode1.json]
-INFO:cfclient.utils.input:Parsing [PS3_Mode_2.json]
-INFO:cfclient.utils.input:Parsing [Generic_OS_X.json]
-INFO:cfclient.utils.input:Parsing [<your input config>.json]
-DEBUG:cflib.crazyflie:Adding callback on port [5] to [<bound method Log._new_packet_cb of <cflib.crazyflie.log.Log instance at 0x82ff08>>]
-DEBUG:cflib.crazyflie:Adding callback on port [0] to [<bound method Console.incoming of <cflib.crazyflie.console.Console instance at 0x90f0f8>>]
-DEBUG:cflib.crazyflie:Adding callback on port [2] to [<bound method _ParamUpdater._new_packet_cb of <_ParamUpdater(Thread-2, initial daemon)>>]
-INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/10/250K]
-INFO:cflib.crazyflie:We are connected[radio://0/10/250K], request connection setup
-DEBUG:cflib.crazyflie.toc:[5]: Start fetching...
-DEBUG:cflib.crazyflie:Adding callback on port [5] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x90fad0>>]
-DEBUG:cflib.crazyflie:ExpectAnswer: Will expect answer on port [5]
-Found [Xbox Gamepad (userspace driver)]
-Will use [Xbox Gamepad (userspace driver)] for input
-DEBUG:cflib.crazyflie:ExpectAnswer: No answer on [5], do retry
-WARNING:cflib.crazyflie:ExpectAnswer: ERROR! Older timer whas running while scheduling new one on [5]
-INFO:cflib.crazyflie:Callback->Connected to [radio://0/10/250K]
-ERROR:cflib.crazyflie.toc:Got packet that was not on TOC channel, TOC fetch will probably not succeed
-DEBUG:cflib.crazyflie:ExpectAnswer: Got answer back on port [5], cancelling timer
-DEBUG:cflib.crazyflie.toc:[5]: Got TOC CRC, 9 items and crc=0x892049D2
-INFO:cflib.crazyflie.toc:TOC for port [5] found in cache
-DEBUG:cflib.crazyflie:Removing callback on port [5] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x90fad0>>]
-DEBUG:cflib.crazyflie.toc:[5]: Done!
-INFO:cflib.crazyflie:Log TOC finished updating
-DEBUG:cflib.crazyflie.toc:[2]: Start fetching...
-DEBUG:cflib.crazyflie:Adding callback on port [2] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x926968>>]
-DEBUG:cflib.crazyflie:ExpectAnswer: Will expect answer on port [2]
-DEBUG:cflib.crazyflie:ExpectAnswer: Got answer back on port [2], cancelling timer
-DEBUG:cflib.crazyflie.toc:[2]: Got TOC CRC, 27 items and crc=0x27A2C4BA
-INFO:cflib.crazyflie.toc:TOC for port [2] found in cache
-DEBUG:cflib.crazyflie:Removing callback on port [2] to [<bound method TocFetcher._new_packet_cb of <cflib.crazyflie.toc.TocFetcher instance at 0x926968>>]
-DEBUG:cflib.crazyflie.toc:[2]: Done!
-INFO:cflib.crazyflie:Param TOC finished updating
-INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/10/250K]
-</code>
-**Note**: If you still have an old version of the headless client you'll need to manually change the URI of your Crazyradio from the default 1M to 250K (make sure the K is uppercase). If you want to use a custom configuration (other than ''PS3_Mode_1'') for the controller or mapping of your choice, copy the .json configuration file to ''~/crazyflie-pc-client/conf/input'' and edit the file ''~/crazyflie-pc-client/lib/cfheadless.py'' (at the [[https://bitbucket.org/bitcraze/crazyflie-pc-client/src/0bd761d9eb4576861025128ef996334721b8f0a3/lib/cfheadless.py?at=dev-headless#cl-108|end of the file]]) with the corresponding filename:
-<code python>
-    app = HeadlessClient(sys.argv,link_uri="radio://0/10/250K",
-                         input_config="<your input config>")
-</code>
-You can then startup the client without any command line arguments and it should hopefully work as well: ''~/crazyflie-pc-client/bin/cfheadless''.
-===== Current state of the headless client =====
-[[http://forum.bitcraze.se/viewtopic.php?p=417#p417|Marcus added]] the following things to note when using the headless client since it is a very early version:
-  * Still dependent on QT (the plan is to remove this very soon)
-  * Not much error handling yet (the plan is to improve this)
-  * Values are still hardcoded in the script (like mapping and URI for Crazyflie). They can be changed at the bottom in lib/cfheadless.py -> **Update** [[https://bitbucket.org/bitcraze/crazyflie-pc-client/pull-request/7/command-line-options-for-radio-uri/diff|A pull request]] adding some command line options for setting the input mapping and radio URI to use has been accepted, update your client to use that.
-  * The headless client will open the first input-device found (so don't plug more than one)
-  * No good way to quit it yet so you will have to kill the process
-===== Make the client startup automatically on Crazyradio plug in =====
-Starting (and killing) the client automatically upon Crazyradio insertion/removal can be done via udev.
-Adjust your Crazyradio udev rule (e.g. ''/etc/udev/rules.d/99-crazyradio.rules'') to look like the following:
-<code>
-SUBSYSTEM=="usb", ATTRS{idVendor}=="1915", ATTRS{idProduct}=="7777", MODE=="0664", GROUP="plugdev", RUN+="/root/bin/cfheadless"
-</code>
-and (as root) create a file ''/root/bin/cfheadless'' with the following contents:
-<code bash>
-#!/bin/sh
-if test "$ACTION" = "add"
-then
-        /usr/bin/sudo -u pi /home/pi/crazyflie-pc-client/bin/cfheadless -u radio://0/10/250K -i <your input config> > /tmp/cfheadless.log 2>&1 &
-        echo $! > /tmp/cfheadless.pid
-else
-        killall -9 cfheadless
-        if test -f /tmp/cfheadless.pid
-        then
-                PID=`cat /tmp/cfheadless.pid`
-                kill -9 $PID
-        fi
-fi
-</code>
-Don't forget to make it executable: ''chmod +x /root/bin/cfheadless''. This should now take care to startup the headless client when you plug in the dongle and (hopefully ;-)) kill it again when you unplug. If you need any additional setup to get your controller working, you can add a similar udev-rule for that to take care of everything upon plugging in the controller as well. An example for the Microsoft Wireless XBox360 controller for PC can be found [[http://forum.bitcraze.se/viewtopic.php?p=490#p490|in this forums post]] or as detailed below.
-And for the XBox360 Controller (after an "apt-get install xboxdrv"):
-Create a udev file ''/etc/udev/rules.d/99-xbox360.rules'' with contents (if using a Microsoft wireless gaming receiver):
-<code bash>SUBSYSTEM=="usb", ATTRS{idVendor}=="045e", ATTRS{idProduct}=="0719", RUN+="/root/bin/xbox360"</code>
-and (as root) create a file ''/root/bin/xbox360'' with the following contents:
-<code bash>#!/bin/sh
-then
-        /usr/bin/xboxdrv &
-else
-        killall -9 xboxdrv
-fi</code>
-:!: **Important** :!: Due to the current state of the client, you **must** make sure to first connect your controller and power up the Crazyflie before connecting the Crazyradio dongle and thus starting the client. If the client can't find either controller or Crazyflie, it will just hang and you'll have to re-plug the dongle again.
-**Troubleshooting** If it still doesn't appear to work, try looking at the logs in the each of the following areas:
-  * /tmp/cfheadless.log
-  * /var/log/syslog
-===== Make your base station portable =====
-If you want to you can make your base station completely portable simply by using a portable USB power supply (e.g. the Anker3 10.000mAh) for powering the Pi. Putting everything into some case and attaching it somewhere on yourself (e.g. your belt) makes you completely mobile while piloting your Crazyflie :-)
-{{https://lh3.googleusercontent.com/-tiQxURfcNcg/UYggKOyaFyI/AAAAAAAADRQ/ZiMZYesmcsM/w1037-h778-no/06.05.13+-+1.jpg?400}}
-{{https://lh5.googleusercontent.com/-_Jd4E3wUjEA/UYrL3mDoJbI/AAAAAAAADUY/senh8FQm6Vc/w1037-h778-no/IMG_20130508_235037.jpg?400}}
misc/hacks/rasberrypi.txt · Last modified: 2021-06-24 16:45 by kimberly
