misc:hacks:rasberrypi [2013-05-21 13:52] foosel [Install the headless client] |
misc:hacks:rasberrypi [2017-05-22 11:43] arnaud [Install the headless client] |
====== Using the Raspberry Pi as a base station for flying ====== | ====== Using the Raspberry Pi as a base station for flying ====== | ||
- | You should setup the CF Headless client (see [[# | + | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. |
+ | The full SD-card image, and instructions on how to install it are located [[http:// | ||
+ | Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user. This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/ | ||
+ | ====== Manual Installation ===== | ||
+ | As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi. | ||
For the following installation instructions it is assumed that you are running the popular [[http:// | For the following installation instructions it is assumed that you are running the popular [[http:// | ||
Line 26: | Line 34: | ||
and start it: '' | and start it: '' | ||
+ | <WRAP center round tip 80%> | ||
+ | **NOTE** | ||
Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | ||
- | python ~/ | + | python ~/ |
The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: | The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: | ||
Line 82: | Line 96: | ||
INFO: | INFO: | ||
+ | ===== Manually Customizing Your .json Configuration File ===== | ||
+ | If you created a customized .json file for your xbox controller using a Windows PC and the cfclient GUI and are planning to copy it over to your Raspberry Pi, here is some advice: | ||
+ | -save the new .json file as something different than the default, so you can recognize it easily. | ||
+ | -the new .json file is not located in the Program Files(x64)/ | ||
+ | -copy your new .json file into the correct RPi folder: / | ||
+ | Right trigger = 4 | ||
Line 113: | Line 156: | ||
[[http:// | [[http:// | ||
Line 128: | Line 171: | ||
Line 134: | Line 177: | ||
if test " | if test " | ||
then | then | ||
echo $! > / | echo $! > / | ||
else | else | ||
Line 146: | Line 189: | ||
- | Don't forget | + | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch |
- | And for the XBox360 Controller (after an " | + | For the XBox360 Controller (after an " |
Line 161: | Line 204: | ||
fi</ | fi</ | ||
+ | <code bash> | ||
- | **Troubleshooting** If it still doesn' | + | **Troubleshooting** |
- | * / | + | If it still doesn' |
+ | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group you created that has root privileges, like ' | ||
+ | ...your controller may very well have already started automatically per the udev rule you created above and could be working correctly and currently is in use. Make sure your wireless xbox controller is powered on and connected (green arc showing), turn on your crazyflie and then plug in your crazyradio. | ||
===== Make your base station portable ===== | ===== Make your base station portable ===== | ||
