misc:hacks:rasberrypi [2013-06-09 23:31] absoloodle37 Clarified how to create the cfheadless and xbox360 executable files in the /root/bin folder |
misc:hacks:rasberrypi [2013-06-10 01:29] absoloodle37 |
Line 29: | Line 29: | ||
Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | ||
- | python ~/ | + | python ~/ |
The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: | The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: | ||
Line 82: | Line 82: | ||
INFO: | INFO: | ||
+ | **Note**: If you created a customized .json file for your xbox controller using a Windows PC and the cfclient GUI and are planning to copy it over to your Raspberry Pi, here is some advice: | ||
+ | -save the new .json file as something different than the default, so you can recognize it easily. | ||
+ | -the new .json file is not located in the Program Files(x64)/ | ||
+ | -copy your new .json file into the correct RPi folder: / | ||
Line 146: | Line 157: | ||
- | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root by typing: sudo -i and then navigating | + | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root: '' |
+ | <code bash> | ||
+ | This should now take care to startup the headless client when you plug in the dongle and (hopefully ;-)) kill it again when you unplug. If you need any additional setup to get your controller working, you can add a similar udev-rule for that to take care of everything upon plugging in the controller as well. An example for the Microsoft Wireless XBox360 controller for PC can be found [[http:// | ||
And for the XBox360 Controller (after an " | And for the XBox360 Controller (after an " | ||
Line 164: | Line 182: | ||
- | **Troubleshooting** If it still doesn' | + | **Troubleshooting** |
- | * / | + | If it still doesn' |
+ | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group you created that has root privileges, like ' | ||
+ | ...your controller may very well have already started automatically per the udev rule you created above and could be working correctly and currently is in use. Make sure your wireless xbox controller is powered on and connected (green arc showing), turn on your crazyflie and then plug in your crazyradio. | ||
===== Make your base station portable ===== | ===== Make your base station portable ===== | ||
