misc:hacks:rasberrypi [2013-06-10 00:52] absoloodle37 Multiple additions (did not delete/change any existing content) |
misc:hacks:rasberrypi [2013-08-13 05:29] absoloodle37 |
Line 83: | Line 83: | ||
- | **Note**: | + | ===== Manually Customizing Your .json Configuration File ===== |
+ | If you created | ||
-save the new .json file as something different than the default, so you can recognize it easily. | -save the new .json file as something different than the default, so you can recognize it easily. | ||
Line 89: | Line 90: | ||
-the new .json file is not located in the Program Files(x64)/ | -the new .json file is not located in the Program Files(x64)/ | ||
- | -copy your new .json file into the correct RPi folder: / | + | -copy your new .json file into the correct RPi folder: / |
- | -the cfheadless client on RPi may not recognize the same controller channel " | + | <code>sudo apt-get install netatalk< |
+ | Right trigger = 4 | ||
Line 124: | Line 142: | ||
[[http:// | [[http:// | ||
Line 139: | Line 157: | ||
Line 157: | Line 175: | ||
- | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root: '' | + | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root: '' |
- | And for the XBox360 Controller (after an " | + | For the XBox360 Controller (after an " |
Line 172: | Line 190: | ||
fi</ | fi</ | ||
+ | <code bash> | ||
Line 180: | Line 207: | ||
- | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group that has root privileges. | + | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group you created |
- | Also, if running the xboxdrv command from a terminal window gives you the following error: 'Error couldn' | + | ...your controller may very well have already started automatically per the udev rule you created above and could be working correctly and currently is in use. Make sure your wireless |
===== Make your base station portable ===== | ===== Make your base station portable ===== |
