misc:hacks:rasberrypi [2013-06-10 01:09] absoloodle37 More clarifying edits |
misc:hacks:rasberrypi [2013-06-11 03:32] absoloodle37 included URL for software to move files from Win PC to RPi |
Line 89: | Line 89: | ||
-the new .json file is not located in the Program Files(x64)/ | -the new .json file is not located in the Program Files(x64)/ | ||
- | -copy your new .json file into the correct RPi folder: / | + | -copy your new .json file into the correct RPi folder: / |
-the cfheadless client on RPi may not recognize the same controller channel " | -the cfheadless client on RPi may not recognize the same controller channel " |
