misc:hacks:rasberrypi [2013-06-10 01:29] absoloodle37 |
misc:hacks:rasberrypi [2013-07-04 14:34] macke [Current state of the headless client] |
Line 89: | Line 89: | ||
-the new .json file is not located in the Program Files(x64)/ | -the new .json file is not located in the Program Files(x64)/ | ||
- | -copy your new .json file into the correct RPi folder: / | + | -copy your new .json file into the correct RPi folder: / |
-the cfheadless client on RPi may not recognize the same controller channel " | -the cfheadless client on RPi may not recognize the same controller channel " | ||
Line 124: | Line 128: | ||
[[http:// | [[http:// | ||
