misc:hacks:rasberrypi [2013-06-10 01:33] absoloodle37 |
misc:hacks:rasberrypi [2013-08-13 03:54] absoloodle37 Identified xbox controller input and corresponding id's in .json file |
Line 83: | Line 83: | ||
- | **Note**: | + | ===== Manually Customizing Your .json Configuration File ===== |
+ | If you created a customized .json file for your xbox controller using a Windows PC and the cfclient GUI and are planning to copy it over to your Raspberry Pi, here is some advice: | ||
-save the new .json file as something different than the default, so you can recognize it easily. | -save the new .json file as something different than the default, so you can recognize it easily. | ||
Line 89: | Line 90: | ||
-the new .json file is not located in the Program Files(x64)/ | -the new .json file is not located in the Program Files(x64)/ | ||
- | -copy your new .json file into the correct RPi folder: / | + | -copy your new .json file into the correct RPi folder: / |
Line 95: | Line 96: | ||
Verify netatalk was installed successfully on your RPi by checking the Finder window on your Mac for a " | Verify netatalk was installed successfully on your RPi by checking the Finder window on your Mac for a " | ||
- | -the cfheadless client on RPi may not recognize the same controller channel " | + | -the cfheadless client on RPi may not recognize the same controller channel " |
+ | Right trigger = 4 | ||
Line 128: | Line 142: | ||
[[http:// | [[http:// | ||
