misc:hacks:rasberrypi [2013-08-13 05:04] absoloodle37 Added clarity and example code |
misc:hacks:rasberrypi [2013-10-03 23:51] absoloodle37 Added links to the SD-card image page and Crubyflie |
====== Using the Raspberry Pi as a base station for flying ====== | ====== Using the Raspberry Pi as a base station for flying ====== | ||
- | You should setup the CF Headless client (see [[# | + | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. |
+ | The full SD-card image, and instructions on how to install it are located [[http:// | ||
+ | Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user. This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/ | ||
+ | ====== Manual Installation ===== | ||
+ | As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi. | ||
For the following installation instructions it is assumed that you are running the popular [[http:// | For the following installation instructions it is assumed that you are running the popular [[http:// | ||
Line 191: | Line 199: | ||
fi</ | fi</ | ||
- | Don't forget to make your files executable after you've created them: '' | + | Don't forget to make your files executable after you've created them: '' |
<code bash> | <code bash> |
