misc:hacks:rasberrypi [2013-05-12 01:18] skube [Install the headless client] |
misc:hacks:rasberrypi [2021-06-24 16:45] (current) kimberly |
| ====== Using the Raspberry Pi as a base station for flying ====== | ====== Using the Raspberry Pi as a base station for flying ====== | ||
| - | You should setup the CF Headless client (see [[# | + | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. |
| + | The full SD-card image, and instructions on how to install it are located [[http:// | ||
| + | Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user. This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/ | ||
| + | ====== Manual Installation ===== | ||
| + | As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi. | ||
| For the following installation instructions it is assumed that you are running the popular [[http:// | For the following installation instructions it is assumed that you are running the popular [[http:// | ||
| Line 19: | Line 30: | ||
| hg up dev-headless | hg up dev-headless | ||
| - | This installs the necessary dependencies for running the client, checks out the current development version from BitBucket and then switches to the branch containing the headless client. | + | This installs the necessary dependencies for running the client, checks out the current development version from BitBucket and then switches to the branch containing the headless client. |
| - | <code python> | + | If you are using an XBox Controller w/ Wireless Gaming Receiver, you might need to also install the userspace driver: |
| - | app = HeadlessClient(sys.argv, | + | |
| - | | + | sudo apt-get install xboxdrv |
| - | </code> | + | |
| + | and start it: '' | ||
| + | <WRAP center round tip 80%> | ||
| + | **NOTE** | ||
| + | All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the //xboxdrv// user-space driver is needed. | ||
| + | </WRAP> | ||
| - | If you are using an XBox Controller w/ Wireless Gaming Receiver, you might need to also install drivers: | + | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client |
| - | sudo apt-get install xboxdrv | + | |
| - | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client((If you get an error message that '' | + | |
| - | python ~/ | + | python ~/ |
| The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: | The client should start up, hopefully find your Crazyradio dongle, your Crazyflie and your controller and start accepting commands: | ||
| - | pi@raspberrypi ~ $ ~/ | + | pi@raspberrypi ~ $ ~/ |
| Info: Using config path: / | Info: Using config path: / | ||
| Info: sys.path= ['/ | Info: sys.path= ['/ | ||
| Line 84: | Line 100: | ||
| + | ===== Manually Customizing Your .json Configuration File ===== | ||
| + | If you created a customized .json file for your xbox controller using a Windows PC and the cfclient GUI and are planning to copy it over to your Raspberry Pi, here is some advice: | ||
| + | -save the new .json file as something different than the default, so you can recognize it easily. | ||
| + | -the new .json file is not located in the Program Files(x64)/ | ||
| + | -copy your new .json file into the correct RPi folder: / | ||
| + | Verify netatalk was installed successfully on your RPi by checking the Finder window on your Mac for a " | ||
| + | -the cfheadless client on RPi may not recognize the same controller channel " | ||
| + | Xbox Controller Input = id# | ||
| + | Left stick vertical = 1 | ||
| + | Left stick horizontal = 0 | ||
| + | Right stick vertical = 3 | ||
| + | Right stick horizontal = 2 | ||
| + | Right trigger = 4 | ||
| + | Customize your flying configuration anyway you like using the inputs/ | ||
| + | **Note**: If you have more than one controller attached, you can select the one to use using the commandline parameter '' | ||
| + | usage: cfheadless [-h] [-u URI] [-i INPUT] [-d] [-c CONTROLLER] | ||
| + | [--controllers] | ||
| + | optional arguments: | ||
| + | -h, --help | ||
| + | -u URI, --uri URI URI to use for connection to the Crazyradio dongle, | ||
| + | defaults to radio:// | ||
| + | -i INPUT, --input INPUT | ||
| + | Input mapping to use for the controller, defaults to | ||
| + | PS3_Mode_1 | ||
| + | -d, --debug | ||
| + | -c CONTROLLER, --controller CONTROLLER | ||
| + | Use controller with specified id, id defaults to 0 | ||
| + | --controllers | ||
| + | **Note**: If you still have an old version of the headless client you'll need to manually change the URI of your Crazyradio from the default 1M to 250K (make sure the K is uppercase). If you want to use a custom configuration (other than '' | ||
| + | <code python> | ||
| + | app = HeadlessClient(sys.argv, | ||
| + | You can then startup the client without any command line arguments and it should hopefully work as well: '' | ||
| ===== Current state of the headless client ===== | ===== Current state of the headless client ===== | ||
| [[http:// | [[http:// | ||
| - | * Still dependent on QT (the plan is to remove this very soon) | + | * <del>Still dependent on QT (the plan is to remove this very soon)</ |
| - | * Not much error handling yet (the plan is to improve this) | + | * <del>Not much error handling yet (the plan is to improve this)</ |
| - | * Values are still hardcoded in the script (like mapping and URI for Crazyflie). They can be changed at the bottom in lib/ | + | * <del>Values are still hardcoded in the script (like mapping and URI for Crazyflie). They can be changed at the bottom in lib/ |
| - | * The headless client will open the first input-device found (so don't plug more than one) | + | * <del>The headless client will open the first input-device found (so don't plug more than one)</ |
| - | * No good way to quit it yet so you will have to kill the process | + | * <del>No good way to quit it yet so you will have to kill the process</ |
| ===== Make the client startup automatically on Crazyradio plug in ===== | ===== Make the client startup automatically on Crazyradio plug in ===== | ||
| Line 103: | Line 174: | ||
| - | and (as root) create a file ''/ | + | and (as root) you will create a file ''/ |
| <code bash> | <code bash> | ||
| Line 109: | Line 180: | ||
| if test " | if test " | ||
| then | then | ||
| echo $! > / | echo $! > / | ||
| else | else | ||
| Line 121: | Line 192: | ||
| - | Don't forget to make it executable: '' | + | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root: '' |
| + | For the XBox360 Controller (after an " | ||
| + | Create a udev file ''/ | ||
| + | <code bash> | ||
| + | and (as root) create a file ''/ | ||
| + | <code bash># | ||
| + | if test " | ||
| + | then | ||
| + | else | ||
| + | killall -9 xboxdrv | ||
| + | fi</ | ||
| + | Don't forget to make your files executable | ||
| + | The -h halts all processes, the -r is the command to reboot after shutdown. | ||
| + | This should now take care to startup the headless client when you plug in the dongle and (hopefully ;-)) kill it again when you unplug. If you need any additional setup to get your controller working, you can add a similar udev-rule for that to take care of everything upon plugging in the controller as well. | ||
| + | :!: **Important** :!: Due to the current state of the client, you **must** make sure to first connect your controller | ||
| + | **Troubleshooting** | ||
| + | If it still doesn' | ||
| + | * /tmp/cfheadless.log (If this log indicates that there' | ||
| + | * /var/ | ||
| + | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group you created that has root privileges, like ' | ||
| + | Also, if running the xboxdrv command from a terminal window gives you the following error: | ||
| - | :!: **Important** :!: Due to the current state of the client, | + | ...your controller may very well have already started automatically per the udev rule you created above and could be working correctly and currently is in use. Make sure your wireless |
| ===== Make your base station portable ===== | ===== Make your base station portable ===== | ||
