misc:hacks:rasberrypi [2013-08-13 05:04] absoloodle37 Added clarity and example code |
misc:hacks:rasberrypi [2021-06-24 16:45] (current) kimberly |
| ====== Using the Raspberry Pi as a base station for flying ====== | ====== Using the Raspberry Pi as a base station for flying ====== | ||
| - | You should setup the CF Headless client (see [[# | + | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. |
| + | The full SD-card image, and instructions on how to install it are located [[http:// | ||
| + | Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user. This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/ | ||
| + | ====== Manual Installation ===== | ||
| + | As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi. | ||
| For the following installation instructions it is assumed that you are running the popular [[http:// | For the following installation instructions it is assumed that you are running the popular [[http:// | ||
| Line 26: | Line 37: | ||
| and start it: '' | and start it: '' | ||
| + | <WRAP center round tip 80%> | ||
| + | **NOTE** | ||
| + | All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the //xboxdrv// user-space driver is needed. | ||
| Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | ||
| Line 191: | Line 208: | ||
| fi</ | fi</ | ||
| - | Don't forget to make your files executable after you've created them: '' | + | Don't forget to make your files executable after you've created them: '' |
| <code bash> | <code bash> | ||
