misc:hacks:rasberrypi [2013-06-10 00:54] absoloodle37 corrected typo |
misc:hacks:rasberrypi [2021-06-24 16:45] kimberly |
====== Using the Raspberry Pi as a base station for flying ====== | ====== Using the Raspberry Pi as a base station for flying ====== | ||
- | You should setup the CF Headless client (see [[# | + | In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box. |
+ | The full SD-card image, and instructions on how to install it are located [[http:// | ||
+ | Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user. This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/ | ||
+ | ====== Manual Installation ===== | ||
+ | As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi. | ||
For the following installation instructions it is assumed that you are running the popular [[http:// | For the following installation instructions it is assumed that you are running the popular [[http:// | ||
Line 26: | Line 37: | ||
and start it: '' | and start it: '' | ||
+ | <WRAP center round tip 80%> | ||
+ | **NOTE** | ||
Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | ||
Line 83: | Line 100: | ||
- | **Note**: | + | ===== Manually Customizing Your .json Configuration File ===== |
+ | If you created | ||
-save the new .json file as something different than the default, so you can recognize it easily. | -save the new .json file as something different than the default, so you can recognize it easily. | ||
Line 89: | Line 107: | ||
-the new .json file is not located in the Program Files(x64)/ | -the new .json file is not located in the Program Files(x64)/ | ||
- | -copy your new .json file into the correct RPi folder: / | + | -copy your new .json file into the correct RPi folder: / |
- | -the cfheadless client on RPi may not recognize the same controller channel " | + | <code>sudo apt-get install netatalk< |
+ | Right trigger = 4 | ||
Line 124: | Line 159: | ||
[[http:// | [[http:// | ||
Line 139: | Line 174: | ||
Line 157: | Line 192: | ||
- | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root: '' | + | You can only create the cfheadless file above in the /root/bin/ folder by being root--not pi or any other user name. Switch to root: '' |
- | And for the XBox360 Controller (after an " | + | For the XBox360 Controller (after an " |
Line 172: | Line 207: | ||
fi</ | fi</ | ||
+ | <code bash> | ||
Line 180: | Line 224: | ||
- | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group that has root privileges. | + | Also, if xboxdrv can't be run without the sudo command, or there are other permissions issues with the xbox wireless usb controller, try adding the the xbox360 wireless receiver to a group you created |
- | Also, if running the xboxdrv command from a terminal window gives you the following error: 'Error couldn' | + | ...your controller may very well have already started automatically per the udev rule you created above and could be working correctly and currently is in use. Make sure your wireless |
===== Make your base station portable ===== | ===== Make your base station portable ===== |
