User Tools
Site Tools
misc:hacks:rasberrypi
Differences
Link to this comparison view
Next revision
Previous revision
misc:hacks:rasberrypi [2013-08-13 05:29]
absoloodle37
misc:hacks:rasberrypi [2021-06-24 16:45]
Line 1: Line 1:
 +</WRAP>
 ====== Using the Raspberry Pi as a base station for flying ====== ====== Using the Raspberry Pi as a base station for flying ======
-You should setup the CF Headless client (see [[#current_state_of_the_headless_client|below]]) instead of the regular PC client on your Pi, since the UI seems to a bit too heavyweight for the Pi (controlling got **very** laggy during tests).+In order to make it easy for users that have a Raspberry Pi to test out our headless client we prepared an SD-card image that is ready to use out of the box.
 +The full SD-card image, and instructions on how to install it are located [[http://wiki.bitcraze.se/projects:crazyflie:binaries:raspberrypi|here.]]
 +Instead of the official Python headless client, there is also a working Ruby version of the headless client, developed by a user.  This version, called Crubyflie, can be installed on top of the SD-card image described above or on a standalone version of Linux/Debian/Raspbian.  It allows you to adjust control variables (like X-mode or max thrust) by changing the values in a configuration file.  For more information visit [[https://github.com/hsanjuan/crubyflie|the Crubyflie installation page.]]
 +====== Manual Installation =====
 +As an alternative to a full SD-card image, you can manually install the headless Python client as a program on your Pi.  You should setup the CF Headless client (see [[#current_state_of_the_headless_client|below]]) instead of the regular PC client on your Pi, since the UI seems to a bit too heavyweight for the Pi (controlling got **very** laggy during tests).
 For the following installation instructions it is assumed that you are running the popular [[http://www.raspbian.org|Raspbian]] distrubution on your Pi.  For the following installation instructions it is assumed that you are running the popular [[http://www.raspbian.org|Raspbian]] distrubution on your Pi.
Line 26: Line 37:
 and start it: ''sudo xboxdrv'' and start it: ''sudo xboxdrv''
 +<WRAP center round tip 80%>
 +**NOTE**
 +All modern Linux distribution now have a kernel driver for the x-box gamepad. Thus it is unlikely the //xboxdrv// user-space driver is needed.
 +</WRAP>
 Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that ''python2'' could not be found, edit ''~/crazyflie-pc-client/bin/cfheadless'' and change the ''python2'' in the first line to ''python'')): Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that ''python2'' could not be found, edit ''~/crazyflie-pc-client/bin/cfheadless'' and change the ''python2'' in the first line to ''python'')):
misc/hacks/rasberrypi.txt · Last modified: 2021-06-24 16:45 by kimberly
