Both sides previous revision Previous revision | Last revision Both sides next revision | ||
misc:hacks:rasberrypi [2015-07-15 16:31] 127.0.0.1 external edit |
misc:hacks:rasberrypi [2017-05-22 11:43] arnaud [Install the headless client] |
Line 34: | Line 34: | ||
and start it: '' | and start it: '' | ||
+ | <WRAP center round tip 80%> | ||
+ | **NOTE** | ||
Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' |
