misc:hacks:rasberrypi [2015-07-15 16:31] 127.0.0.1 external edit |
misc:hacks:rasberrypi [2021-06-24 16:45] kimberly |
====== Using the Raspberry Pi as a base station for flying ====== | ====== Using the Raspberry Pi as a base station for flying ====== | ||
Line 34: | Line 37: | ||
and start it: '' | and start it: '' | ||
+ | <WRAP center round tip 80%> | ||
+ | **NOTE** | ||
Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' | Plugin your Crazyradio and your controller, power up the Crazyflie and start the client (via SSH and Ethernet or by using an USB hub to connect Crazyradio, controller and keyboard)((If you get an error message that '' |
