misc:hacks:topleddeck [2019-06-04 10:57] kimberly |
misc:hacks:topleddeck [2019-06-04 12:15] kimberly |
====== LED deck on top with flow deck ====== | ====== LED deck on top with flow deck ====== | ||
- | With the LED deck and a Crazyflie 2.x, we are able to make real pieces of art, like in the light paintings in this [[https:// | + | With the [[https:// |
__How about using the LED-deck in the combination with the [[https:// | __How about using the LED-deck in the combination with the [[https:// | ||
Line 12: | Line 12: | ||
* Hotglue or tape | * Hotglue or tape | ||
- | What we are essentially doing, is that we are flipping the pin-layout of the LEDdeck | + | What we are essentially doing, is that we are flipping the pin-layout of the LED deck so that it is compatible to be put on the top of the Crazyflie. |
- | The image below shows how you should solder the wiring. The **Gnd** (ground),** IO2**, **OW** (deck memory), and **VCOM** (power supply). Please check out this [[projects: | + | The image below shows how you should solder the wiring. The **Gnd** (ground),** IO2**, **OW** (deck single wire memory), and **VCOM** (power supply). Please check out this [[projects: |
Line 24: | Line 24: | ||
<WRAP center round important 60%> | <WRAP center round important 60%> | ||
- | We did not connect **IO3** on purpose since the Flow deck v2 is already using this for it's own, or else the LED deck and Flow deck will conflict with each other' | + | We did not connect **IO3** on purpose since the Flow deck v2 is already using this, or else the LED deck and Flow deck will conflict with each other' |
- | The battery holder deck can be glued on the LED-deck or attached with some tape.The wiring and soldering | + | The battery holder deck can be glued on the LED-deck or attached with some tape.The wiring and soldering |
+ | __Please pay attention to that the orientation of the LED deck is now different__. We put the battery holder on the side to prevent any connections to short with the LED deck, but now you would need to indicate the new ' | ||
+ | We tested the converted LED deck with the Flow deck v2 with the CFclient and we are still receiving the values and parameters from both the deck drivers. At the moment of writing **we haven' | ||
