misc:hacks:topleddeck [2019-06-04 12:08] kimberly |
misc:hacks:topleddeck [2021-06-24 16:46] kimberly |
====== LED deck on top with flow deck ====== | ====== LED deck on top with flow deck ====== | ||
- | With the [[https:// | + | With the [[https:// |
__How about using the LED-deck in the combination with the [[https:// | __How about using the LED-deck in the combination with the [[https:// | ||
Line 14: | Line 17: | ||
What we are essentially doing, is that we are flipping the pin-layout of the LED deck so that it is compatible to be put on the top of the Crazyflie. | What we are essentially doing, is that we are flipping the pin-layout of the LED deck so that it is compatible to be put on the top of the Crazyflie. | ||
- | The image below shows how you should solder the wiring. The **Gnd** (ground),** IO2**, **OW** (deck single wire memory), and **VCOM** (power supply). Please check out this [[projects: | + | The image below shows how you should solder the wiring. The **Gnd** (ground),** IO2**, **OW** (deck single wire memory), and **VCOM** (power supply). Please check out this [[projects: |
Line 24: | Line 27: | ||
<WRAP center round important 60%> | <WRAP center round important 60%> | ||
- | We did not connect **IO3** on purpose since the Flow deck v2 is already using this for it's own, or else the LED deck and Flow deck will conflict with each other' | + | We did not connect **IO3** on purpose since the Flow deck v2 is already using this, or else the LED deck and Flow deck will conflict with each other' |
- | The battery holder deck can be glued on the LED-deck or attached with some tape.The wiring and soldering | + | The battery holder deck can be glued on the LED-deck or attached with some tape.The wiring and soldering |
__Please pay attention to that the orientation of the LED deck is now different__. We put the battery holder on the side to prevent any connections to short with the LED deck, but now you would need to indicate the new ' | __Please pay attention to that the orientation of the LED deck is now different__. We put the battery holder on the side to prevent any connections to short with the LED deck, but now you would need to indicate the new ' |
