misc:hacks:topleddeck [2019-06-04 12:11] kimberly |
misc:hacks:topleddeck [2019-06-04 12:15] kimberly |
Line 14: | Line 14: | ||
What we are essentially doing, is that we are flipping the pin-layout of the LED deck so that it is compatible to be put on the top of the Crazyflie. | What we are essentially doing, is that we are flipping the pin-layout of the LED deck so that it is compatible to be put on the top of the Crazyflie. | ||
- | The image below shows how you should solder the wiring. The **Gnd** (ground),** IO2**, **OW** (deck single wire memory), and **VCOM** (power supply). Please check out this [[projects: | + | The image below shows how you should solder the wiring. The **Gnd** (ground),** IO2**, **OW** (deck single wire memory), and **VCOM** (power supply). Please check out this [[projects: |
Line 24: | Line 24: | ||
<WRAP center round important 60%> | <WRAP center round important 60%> | ||
- | We did not connect **IO3** on purpose since the Flow deck v2 is already using this for it's own, or else the LED deck and Flow deck will conflict with each other' | + | We did not connect **IO3** on purpose since the Flow deck v2 is already using this, or else the LED deck and Flow deck will conflict with each other' |
