misc:investigations:lps-max-range [2017-03-21 16:15] kristoffer |
misc:investigations:lps-max-range [2017-04-18 18:16] arnaud |
Line 12: | Line 12: | ||
The LEDs on the deck and anchor indicates when the module is in transmit and receive mode as well as when a ranging operation is completed. Our measurement method was simply to walk away from the anchor with the Crazyflie and watch the LEDs and observe when we stared to loose packets. | The LEDs on the deck and anchor indicates when the module is in transmit and receive mode as well as when a ranging operation is completed. Our measurement method was simply to walk away from the anchor with the Crazyflie and watch the LEDs and observe when we stared to loose packets. | ||
+ | The radios are setup on //channel 2// with preamble rate of //64MHz//, preamble lenght of 128 and datarate of // | ||
=== Power settings === | === Power settings === | ||
Line 27: | Line 29: | ||
Indoors there are walls, the floor and other objects that bounces and echoes the radio waves sent out by the system. Outside there are usually fewer obstacles and typically only the ground that effects the transmitted energy. Obviously this makes a difference and we wanted to see if we could measure it. | Indoors there are walls, the floor and other objects that bounces and echoes the radio waves sent out by the system. Outside there are usually fewer obstacles and typically only the ground that effects the transmitted energy. Obviously this makes a difference and we wanted to see if we could measure it. | ||
- | Note that echoes might actually be something good that increases | + | Note that for an ultra-wideband system echo and multipath can actually |
The " | The " | ||
- | For outdoors measurements we used the street outside the office. It is fairly open but the buildings on the sides are probably affecting the results somewhat. | + | For outdoors measurements we used the street outside the office. It is fairly open but the buildings on the sides are probably affecting the results somewhat. |
=== Antenna orientation === | === Antenna orientation === |
