misc:investigations:lps-max-range [2017-03-24 09:02] arnaud |
misc:investigations:lps-max-range [2021-06-24 16:39] (current) kimberly |
====== Measurements of maximum ranges for the Loco Positioning system ====== | ====== Measurements of maximum ranges for the Loco Positioning system ====== | ||
Line 12: | Line 16: | ||
The LEDs on the deck and anchor indicates when the module is in transmit and receive mode as well as when a ranging operation is completed. Our measurement method was simply to walk away from the anchor with the Crazyflie and watch the LEDs and observe when we stared to loose packets. | The LEDs on the deck and anchor indicates when the module is in transmit and receive mode as well as when a ranging operation is completed. Our measurement method was simply to walk away from the anchor with the Crazyflie and watch the LEDs and observe when we stared to loose packets. | ||
+ | The radios are setup on //channel 2// with preamble rate of //64MHz//, preamble lenght of 128 and datarate of // | ||
=== Power settings === | === Power settings === |
