misc:investigations:lps-precision [2017-05-11 15:20] kristoffer |
misc:investigations:lps-precision [2017-07-07 09:29] arnaud [The results] |
Line 23: | Line 23: | ||
| 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | | | 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | | ||
+ | [[https:// | ||
===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ||
Line 47: | Line 48: | ||
=== Analysis === | === Analysis === | ||
+ | == Estimated position == | ||
+ | ^ Physical position ^^^ Average estimated position ^^^^^^ Std-dev of estimated position ^^^ Average error ^ | ||
+ | ^ X ^ Y ^ Z ^ X ^ Err ^ Y ^ Err ^ Z ^ Err ^ X ^ Y ^ Z ^ distance ^ | ||
+ | | 5.00 | 1.50 | 0.76 | 4.96 | 0.017 | 1.60 | 0.041 | -0.096 | -0.213 | 0.017 | 0.018 | 0.015 | 0.237 | | ||
== Raw range measurements == | == Raw range measurements == | ||
Line 54: | Line 61: | ||
Average and standard deviations are calculated on all data, including outliers. | Average and standard deviations are calculated on all data, including outliers. | ||
- | The main part of the error should be the caused by the antenna delay, expected to be the same for all anchors. | + | The main part of the error should be caused by the antenna delay, expected to be the same for all anchors. |
^ ^ Physical ^ Raw range measurements ^^^ | ^ ^ Physical ^ Raw range measurements ^^^ | ||
Line 65: | Line 72: | ||
| 5 | 2.20 | 1.90 | 0.008 | 0.30 | | | 5 | 2.20 | 1.90 | 0.008 | 0.30 | | ||
- | == Estimated position | + | == Histogram over raw range measurements |
- | ^ Physical position ^^^ Average estimated position ^^^^^^ Std-dev of estimated position ^^^ | + | |
- | ^ X ^ Y ^ Z ^ X ^ Err ^ Y ^ Err ^ Z ^ Err ^ X ^ Y ^ Z ^ | + | |
