Next revision | Previous revision Last revision Both sides next revision | ||
misc:investigations:lps-precision [2017-03-23 17:10] kristoffer created |
misc:investigations:lps-precision [2017-07-07 09:50] arnaud [The results] |
====== Measurements of accuracy and precision of the Loco Positioning system ====== | ====== Measurements of accuracy and precision of the Loco Positioning system ====== | ||
- | To indicate the accuracy and precision of the Loco Positioning system, we have made a few measurements on our reference system. The measurements were performed on a static Crazyflie using the log system of the client. We put the Crazyflie in a few known positions and logged the estimated position in the Crazyflie for further analyses. For each position 2000 samples were collected and the average and standard deviation were calculated for x, y, and z. | + | To indicate the accuracy and precision of the Loco Positioning system, we have made a few measurements on our reference system. The measurements were performed on a static Crazyflie using the log system of the client. We put the Crazyflie in a few known positions and logged the estimated position in the Crazyflie for further analyses. For each position 2000@100Hz |
+ | The errors when we measured the physical positions of anchors and the Crazyflie is probably in the +/- 5 cm range. | ||
These measurements are in no way meant to be a specification of the system properties of the Loco Positioning system, but are intended to give an indication of the performance. | These measurements are in no way meant to be a specification of the system properties of the Loco Positioning system, but are intended to give an indication of the performance. | ||
+ | ===== Multiple measurements in reference system ===== | ||
==== The reference system ==== | ==== The reference system ==== | ||
- | The reference system is based on the indoor explorer bundle: one Crazyflie with a Loco Positioning Deck and six Loco Positioning Anchors. See the [[doc: | + | The reference system is based on the indoor explorer bundle: one Crazyflie with a Loco Positioning Deck and six Loco Positioning Anchors. See the [[doc: |
All measurements were done in the Two way ranging mode. | All measurements were done in the Two way ranging mode. | ||
==== The results ==== | ==== The results ==== | ||
- | ^ Physical position ^^^ Average estimated position ^^^ Std deviation | + | ^ Physical position ^^^ Average estimated position |
- | ^ X ^ Y ^ Z ^ X ^ Y ^ Z ^ X ^ Y ^ Z ^ | + | ^ X ^ Y ^ Z ^ X ^ Err ^ Y ^ Err ^ Z ^ Err ^ X ^ Y ^ Z ^ |
- | ^ 1.62 ^ 3.15 ^ -0.15 ^ X ^ Y ^ Z ^ X ^ Y ^ Z ^ | + | | 1.62 | 3.15 | -0.15 | 1.66 |0.04 | 3.18 |0.03 | 0.29 |0.44 | 0.014 | 0.0097 | 0.0061 | |
- | ^ 0.00 ^ 2.95 ^ -0.15 ^ X ^ Y ^ Z ^ X ^ Y ^ Z ^ | + | | 2.95 | 0.00 | -0.15 | 2.80 |-0.15| 0.12 |0.12 | 0.16 |0.31 | 0.0072 | 0.010 | 0.0053 | |
- | ^ 1.62 ^ 3.15 ^ 1.44 ^ X ^ Y ^ Z ^ X ^ Y ^ Z ^ | + | | 1.62 | 3.15 | 1.44 | 1.56 |0.06 | 3.02 |-0.13| 1.37 |-0.07| 0.020 | 0.0066 | 0.016 | |
- | ^ 1.62 ^ 4.8 ^ 1.44 ^ X ^ Y ^ Z ^ X ^ Y ^ Z ^ | + | | 1.62 | 4.80 | 1.44 | 1.67 |0.03 | 4.64 |-0.16| 1.40 |-0.27| 0.013 | 0.0093 | 0.013 | |
+ | [[https:// | ||
+ | ===== Measurement of accuracy and noise of 3D estimate and ranges ===== | ||
+ | ==== Setup ==== | ||
+ | The system is setup with 6 anchors and one Crazyflie ranging in two-way-ranging mode. The Crazyflie in static position without movement. | ||
+ | === Positions === | ||
+ | ^ Anchor | ||
+ | | 0 | 3.01 | 0.57 | 2.5 | | ||
+ | | 2 | 6.53 | 2.27 | 2.84 | | ||
+ | | 4 | 2.91 | 0.86 | 0.16 | | ||
+ | | 5 | 6.95 | 2.32 | 0.16 | | ||
+ | Crazyflie: (x,y,z) = (5.00, | ||
+ | === Measurements === | ||
+ | * Kalman filter 3D estimated position: https:// | ||
+ | * Raw range measurement (not taken at the same time as the kalman estimate): https:// | ||
+ | === Analysis === | ||
+ | == Estimated position == | ||
+ | ^ Physical position | ||
+ | ^ X ^ Y ^ Z ^ X ^ Err ^ Y ^ Err ^ Z ^ Err ^ X ^ Y ^ Z ^ distance ^ | ||
+ | | 5.00 | 1.50 | 0.76 | 4.96 | 0.017 | 1.60 | 0.041 | -0.096 | -0.213 | 0.017 | 0.018 | 0.015 | 0.237 | | ||
+ | == Raw range measurements == | ||
+ | Physical distances from Crazyflie to anchors are calculated from positions of anchors and the Crazyflie. | ||
+ | Average and standard deviations are calculated on all data, including outliers. | ||
+ | The main part of the error should be caused by the antenna delay, expected to be the same for all anchors. | ||
+ | ^ ^ Physical ^ Raw range measurements ^^^ | ||
+ | ^ Anchor ^ Distance ^ Average ^ Std dev ^ Err ^ | ||
+ | | 0 | 2.80 | 2.46 | 0.025 | 0.34 | | ||
+ | | 1 | 2.87 | 2.58 | 0.006 | 0.30 | | ||
+ | | 2 | 2.69 | 2.30 | 0.002 | 0.40 | | ||
+ | | 3 | 2.77 | 2.55 | 0.017 | 0.22 | | ||
+ | | 4 | 2.27 | 1.97 | 0.041 | 0.29 | | ||
+ | | 5 | 2.20 | 1.90 | 0.008 | 0.30 | | ||
+ | == Histogram over raw range measurements == | ||
