Next revision | Previous revision Last revision Both sides next revision | ||
misc:usbwindows [2017-07-06 11:52] arnaud created |
misc:usbwindows [2019-09-05 14:50] kimberly |
+ | https:// | ||
+ | and | ||
+ | https:// | ||
====== Installing USB driver on Windows ====== | ====== Installing USB driver on Windows ====== | ||
- | Most bitcraze | + | Most Bitcraze |
===== Install the driver ===== | ===== Install the driver ===== | ||
- | First of all download Zadig from its website: http:// | + | First of all download Zadig from its website: http:// |
- | Plug the Bitcraze device in the PC. Windows should display some installation window. On windows 8 and 10 it does nothing and closes itself. On windows 7 you have to close the install failed window. On Windows XP just click " | + | Plug the Bitcraze device in the PC. Windows should display some installation window. On windows 8 and 10 it does nothing and closes itself. On windows 7 you have to close the install failed window. |
- | Once windows is out of the way, launch Zadig, you should see your device in the list. Select the device, select libusb and click install: | + | Once windows is out of the way, launch Zadig, you should see your device in the list. Select the device, select |
