misc:usbwindows [2017-07-06 11:54] arnaud |
misc:usbwindows [2019-05-29 13:08] arnaud |
Line 7: | Line 7: | ||
First of all download Zadig from its website: http:// | First of all download Zadig from its website: http:// | ||
- | Plug the Bitcraze device in the PC. Windows should display some installation window. On windows 8 and 10 it does nothing and closes itself. On windows 7 you have to close the install failed window. On Windows XP just click " | + | Plug the Bitcraze device in the PC. Windows should display some installation window. On windows 8 and 10 it does nothing and closes itself. On windows 7 you have to close the install failed window. |
- | Once windows is out of the way, launch Zadig, you should see your device in the list. Select the device, select libusb and click install: | + | Once windows is out of the way, launch Zadig, you should see your device in the list. Select the device, select |
