misc:usbwindows [2017-07-06 11:57] arnaud |
misc:usbwindows [2020-05-12 14:11] kimberly |
====== Installing USB driver on Windows ====== | ====== Installing USB driver on Windows ====== | ||
Line 11: | Line 16: | ||
- | Once windows is out of the way, launch Zadig, you should see your device in the list. Select the device, select libusb and click install: | + | Once windows is out of the way, launch Zadig, you should see your device in the list. Select the device, select |
