projects:accessories:chg500:index [2017-01-16 16:15] macke |
projects:accessories:chg500:index [2021-06-24 16:16] kimberly |
====== Overview and specification ====== | ====== Overview and specification ====== | ||
- | External 1-cell li-po charger with micro-USB connector. For full specification please see the [[https:// | + | External 1-cell |
====== Hardware ====== | ====== Hardware ====== | ||
Line 9: | Line 14: | ||
====== Chaining ====== | ====== Chaining ====== | ||
- | Using the P2 connector it's possible to chain multiple chargers together and only power one. This requires soldering. Below is a picture of one possible setup. | + | Using the P2 connector it's possible to chain multiple chargers together and only power one. This requires soldering. Below is a picture of one possible setup. Don't forget to check the rating of the connectors and make sure you use a power supply that can supply at least 500mA per charger. |
<WRAP group> | <WRAP group> | ||
<WRAP half column> | <WRAP half column> |
