projects:accessories:chg500:index [2017-01-16 15:54] macke created |
projects:accessories:chg500:index [2021-06-24 16:16] (current) kimberly |
| ====== Overview and specification ====== | ====== Overview and specification ====== | ||
| + | External 1-cell 500mA li-po charger with micro-USB connector. For full specification please see the [[https:// | ||
| ====== Hardware ====== | ====== Hardware ====== | ||
| - | {{ : | + | Revision A {{ : |
| - | ====== Chaining ====== | + | Revision A layout seen from the top |
| + | ====== Chaining ====== | ||
| + | Using the P2 connector it's possible to chain multiple chargers together and only power one. This requires soldering. Below is a picture of one possible setup. Don't forget to check the rating of the connectors and make sure you use a power supply that can supply at least 500mA per charger. | ||
| + | <WRAP group> | ||
| + | <WRAP half column> | ||
