User Tools
Site Tools
projects:bolt:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:bolt:index [2019-10-08 14:12]
tobias [Example setup]
projects:bolt:index [2019-12-09 15:17] (current)
tobias [Specification]
Line 5: Line 5:
 ====== Crazyflie Bolt ====== ====== Crazyflie Bolt ======
-The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1 but in a slightly bit bigger package.+The Crazyflie Bolt is a Crazyflie 2.X compatible flight controller for brushless builds. It is intended to have the strengths of the Crazyflie 2.1but in a slightly bit bigger package
 +===== Board renderings =====
 +The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames.
 {{:projects:bolt:bolt-front.png?nolink&400 |}} {{:projects:bolt:bolt-front.png?nolink&400 |}}
 {{:projects:bolt:bolt-back.png?nolink&400| }} {{:projects:bolt:bolt-back.png?nolink&400| }}
-The size of the board is 36mm x 35.4mm and the holes are M3, located at the common 30.5mm square, to fit most frames.
 ===== Specification ===== ===== Specification =====
-Please see the shop product page for full specification <add link>+Please see the [[https://store.bitcraze.io/collections/kits/products/crazyflie-bolt|shop product page]] for full specification.
 ===== Features and differences from Crazyflie 2.1 =====  ===== Features and differences from Crazyflie 2.1 =====
Line 30: Line 33:
 ===== Power ===== ===== Power =====
-The Bolt contains a power distribution board (PDB) but it is a bit limiting. Both as the current has to pass a MOSFET and the ESC connector. We have tested running 8A though the chain without any limiting heat-up but that is as far as we would recommend to go. If increased current is wanted one could bypass the connectors by soldering the ESC directly to the connector soldering pad. The MOSFET is still there but a slight increase should be possible. For higher currents, an external PDB should be used. Other tricks to keep current down, but power up, is to run on higher voltage (3S or 4S) and using low KV motors.+The Bolt contains a power distribution board (PDB) but it is a bit limiting. The current has to pass a MOSFET, to be able to switch it off, and also the ESC connector. We have tested running 8A though the chain without any limiting heat-upbut that is as far as we would recommend to go. If additional current is wantedone could bypass the connectors by soldering the ESC directly to the connector soldering pad. The MOSFET is still there but a slight increase should be possible. For higher currents, an external PDB should be used. Other tricks to keep current down, but power up, is to run on higher voltage (3S or 4S) and using low KV motors.
 ===== Schematics ===== ===== Schematics =====
projects/bolt/index.1570536736.txt.gz · Last modified: 2019-10-08 14:12 by tobias
