projects:crazyflie2:development:openocd_gdb_debugging [2019-06-26 16:20] kimberly |
projects:crazyflie2:development:openocd_gdb_debugging [2019-07-02 13:45] victor |
====== On-chip debugging ====== | ====== On-chip debugging ====== | ||
- | One of the key components of getting really serious about developing on the crazyflie, is time to dive into the C-based firmware. If you really want to do some major changes to the intrinsic of the code, it is essential to have proper tools to be able to debug the code (place breakpoints, | + | One of the key components of getting really serious about developing on the crazyflie, is to dive into the C-based firmware. If you really want to do some major changes to the intrinsic of the code, it is essential to have proper tools to be able to debug the code (place breakpoints, |
<WRAP center round info 60%> | <WRAP center round info 60%> | ||
Line 36: | Line 36: | ||
Then install eclipse itself: | Then install eclipse itself: | ||
- | Go to their download page: [[https:// | + | Go to their download page: [[https:// |
- | and then go into you download folder | + | |
- | tar -zxvf eclipse-cpp-2019-03-R-linux-gtk-x86_64.tar.gz | + | tar -zxvf "your-downloaded-file".tar.gz |
and start up eclipse: | and start up eclipse: | ||
- | cd EXTRACT FOLDER/ | + | "YOUR-UNZIPPED-FOLDER" |
- | ./eclipse | + | |
=== Installing required Eclipse Plugins === | === Installing required Eclipse Plugins === | ||
- | Install the c++ development tools and GNU MCU plugin by following the instructions | + | Install the C++ development tools and GNU MCU plugin by following the instructions [[https:// |
- | * C++ development tools: Go to header ' | + | * C++ Development - Follow the instructions under the header ' |
- | * GNU MCU plugin: Go to header ' | + | * GNU MCU plugin |
=== Import Crazyflie Firmware === | === Import Crazyflie Firmware === | ||
Line 59: | Line 57: | ||
First import the [[https:// | First import the [[https:// | ||
- | *File> | + | *File > import... |
- | *C/C++ > Existing Code as Makefile Project | + | *C/C++ > Existing Code as Makefile Project |
+ | *Give it a name | ||
*Existing Code Location > Browse... > //Look for the firmware folder// | *Existing Code Location > Browse... > //Look for the firmware folder// | ||
*Finish | *Finish | ||
=== Setting up Eclipse Debugging environment === | === Setting up Eclipse Debugging environment === | ||
- | * Go to: Run> | + | * Go to: Run > Debug Configurations... |
* Double click 'GDB OpenOCD Debugging' | * Double click 'GDB OpenOCD Debugging' | ||
Line 75: | Line 76: | ||
+ | Insert the filepath to the cf2.elf file to //C/C++ Application// | ||
Line 82: | Line 86: | ||
check the following settings: | check the following settings: | ||
- | OpenOCD setup -> Config options: -f interface/ | + | OpenOCD setup -> Config options: |
- | GDB Client Setup -> Commands: set mem inaccessible-by-default off | + | GDB Client Setup: |
+ | * Executable name: Filepath to gdb toolchain | ||
+ | * Commands: < | ||
== Startup == | == Startup == | ||
Line 98: | Line 104: | ||
+ | ==== Mac OS ==== | ||
+ | Install gdb and openocd | ||
+ | brew install gdb | ||
+ | brew install open-ocd | ||
+ | Install java JDK [[https:// | ||
+ | Download eclipse [[https:// | ||
+ | Choose destination folders - Install | ||
+ | Run eclipse and choose work folder | ||
+ | == Installing required eclipse Plugins == | ||
+ | The rest is the same as for Linux. | ||
+ | Make sure that the arm-none-eabi-gcc is properly installed and its path is configured in the //debug configurations// |
