projects:crazyflie2:expansionboards:bigquad [2019-10-03 14:58] tobias [Current firmware status notes (2019-10)] |
projects:crazyflie2:expansionboards:bigquad [2020-01-23 15:56] tobias [Setting up] |
Line 74: | Line 74: | ||
Currently there is only a basic setup but as the development advances so will the documentation. | Currently there is only a basic setup but as the development advances so will the documentation. | ||
- | Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below. | + | Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below. **Note** that the 5V is needed for the motor signals and is not optional. |
===== Basic connection diagram ===== | ===== Basic connection diagram ===== |
