BigQuad expansion deck
Specification
  • 4 x ESC connectors
    • CPPM input (3 pin)
    • GPS input (4 pin)
    • I2C expansion (4 pin)
    • Buzzer output (2 pin)
Electrical specification:
Mechanical specification:
  • Weight: 3.8g
  • Size (WxHxD): 36x40x5mm
Package contents:
  • 1 x BigQuad deck
  • 4 x M2x4 nylon screw
  • 2 x M2x6 hex spacer
Schematic
Setting up
Currently there is only a basic setup but as the developments advance so will the documentation. Start by mounting the big quad deck on the frame. After that connect the ESCs according to the diagrams below.
Basic connection diagram
Basic connection picture
Attaching the Crazyflie 2.0
If the frame allows the Crazyflie 2.0 motors to be kept mounted but it is fine to remove them as well. Attach and connect the Crazyflie 2.0 using either the long or short deck pins. Use the included nylon spacer and screws to secure the Crazyflie 2.0 in place and to keep it level.
Building Firmware
Enable BigQuad features
CFLAGS += -DENABLE_BQ_DECK
Reference setup
projects/crazyflie2/expansionboards/bigquad.1457443334.txt.gz · Last modified: 2016-03-08 14:22 by tobias
