projects:crazyflie2:expansionboards:bosch [2017-05-23 15:36] jan [Setting Up] |
projects:crazyflie2:expansionboards:bosch [2021-06-24 16:13] (current) kimberly |
+ | [[https:// | ||
====== Bosch Sensor Deck ====== | ====== Bosch Sensor Deck ====== | ||
Line 7: | Line 13: | ||
- | As there are different versions of the sensor deck, some sensors are only avaible | + | As there are different versions of the sensor deck, some sensors are only available |
- | * Intertial | + | * Inertial |
* triaxial 12-bit accelerometer (up to ± 16g) | * triaxial 12-bit accelerometer (up to ± 16g) | ||
Line 55: | Line 61: | ||
Now you are ready to make the firmware and flash it on your crazyflie. | Now you are ready to make the firmware and flash it on your crazyflie. | ||
- | For evaluation purposes you might want to log sensors data what can be done with help of the [[projects: | + | For evaluation purposes you might want to log sensors data which can be done with help of the [[projects: |
