projects:crazyflie2:expansionboards:index [2018-03-14 09:11] kristoffer [Deck pin allocation] |
projects:crazyflie2:expansionboards:index [2018-05-08 13:10] tobias [Deck info] |
Line 54: | Line 54: | ||
| 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | ||
Line 72: | Line 76: | ||
| bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | | bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | ||
| bcOA | | | X | X | | | | | | | | | | | | VCC | | | bcOA | | | X | X | | | | | | | | | | | | VCC | | ||
