projects:crazyflie2:expansionboards:index [2018-03-14 09:11] kristoffer [Deck pin allocation] |
projects:crazyflie2:expansionboards:index [2020-02-11 09:58] tobias |
+ | This page is deprecated and is moved to the main Bitcraze website. Please go to [[https:// | ||
Line 4: | Line 9: | ||
+ | * [[projects: | ||
Line 10: | Line 16: | ||
+ | [[projects: | ||
Line 36: | Line 46: | ||
Line 54: | Line 71: | ||
| 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | | 0xBC | 0x0B | bcOA | Obstacle Avoidance | N/A | ~0.3mA | Above | N/A | N/A | | ||
Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | Below is a table showing which pins each deck uses. The table also contains information about boards that are not released yet, these are subject to change. | ||
Line 61: | Line 84: | ||
- | | bcOA | | | X | X | | | | | | | | | | | | VCC | | + | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | |
+ | ^ LED-ring | ||
+ | ^ Qi charger | ||
+ | ^ Micro-SD | ||
+ | ^ UWB LPS | yes | ||
+ | ^ Buzzer | ||
+ | ^ Multi-ranger | ||
+ | ^ Lighthouse-4 | ||
+ | ^ LED-ring | ||
+ | ^ Micro-SD | ||
+ | ^ Buzzer | ||
+ | ^ Flow, Flow V2 | ||
+ | **Notes:** | ||
