projects:crazyflie2:expansionboards:index [2019-02-14 13:47] kristoffer |
projects:crazyflie2:expansionboards:index [2020-05-12 13:58] kimberly |
Line 13: | Line 18: | ||
+ | * [[projects: | ||
[[projects: | [[projects: | ||
Line 86: | Line 92: | ||
^ bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | ^ bcBuzzer | | | | | | | | | PWM | PWM | | | | | | N/A | | ||
^ bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ^ bcESP | | | | | | | | //(X)// | X | X | | | | | | N/A | | ||
- | ^ bcZRanger | | | X | X | | //(X)// | | | | | | | | | | VCC | | + | ^ bcZRanger, bcZRanger2 |
- | ^ bcFlow | | | X | X | | //(X)// | X | | | | X | X | X | | | VCC | | + | ^ bcFlow, bcFlow2 |
^ bcOA | | | X | X | | | | | | | | | | | | VCC | | ^ bcOA | | | X | X | | | | | | | | | | | | VCC | | ||
^ bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | ^ bcMultiranger | | | X | X | | | | | | | | | | | | VCOM | | ||
Line 99: | Line 105: | ||
This table shows which deck that works on which platform. | This table shows which deck that works on which platform. | ||
- | ^ bcLedRing | + | ^ LED-ring |
- | ^ bcQi | + | ^ Qi charger |
- | ^ bcGPS | yes | + | ^ Micro-SD |
- | ^ bcUSD | yes | *1 | | + | ^ UWB LPS | yes |
- | ^ bcDWM | yes | + | ^ Big quad |
- | ^ bcBigQuad | + | ^ Buzzer |
- | ^ bcBuzzer | + | ^ bcESP |
- | ^ bcESP | + | ^ Z-Ranger, Z-Ranger V2 | yes | yes | |
- | ^ bcZRanger | + | ^ Flow, Flow V2 | yes | yes | |
- | ^ bcFlow | + | ^ Multi-ranger |
- | ^ bcOA | yes | yes | | + | ^ Mocap marker deck | yes | yes | |
- | ^ bcMultiranger | + | ^ Lighthouse-4 |
- | ^ bcMocap | + | |
- | ^ bcLighthouse4 | + | |
==== Deck - deck ==== | ==== Deck - deck ==== | ||
Line 124: | Line 128: | ||
blocking each other are marked as not compatible. | blocking each other are marked as not compatible. | ||
- | ^ bcGPS | yes | yes | | yes | + | ^ Micro-SD |
- | ^ bcUSD | yes | + | ^ UWB LPS | yes | yes | *1 |
- | ^ bcESP | + | ^ Z-Ranger, Z-Ranger V2 | | | yes | yes |
- | ^ bcZRanger | + | ^ Flow, Flow V2 | | | *1 |
- | ^ bcOA | yes | yes | yes | yes | yes | yes | yes | yes | + | ^ Mocap marker deck | yes | yes | yes | yes |
**Notes:** | **Notes:** | ||
- SPI sharing issue, see https:// | - SPI sharing issue, see https:// | ||
- Will be supported in the future, SW update | - Will be supported in the future, SW update |
